Midwest Super Stearman CG
My Feedback: (33)
QC, CANADA
Hello there!
Does anybody know where the Center of Gravity is located for a Midwest Super Stearman?
any help will be greatly appreciated,
thanks in advance,
Humberto Ollervides
Quebec, Canada
thanks in advance,
Humberto Ollervides
Quebec, Canada
I just finished building a Midwest Stearman.
The CG is determined but looking down on the top of the assembled plane.
Measure the distance from the leading edge of the top wing to the trailing edge of the bottom wing. Then 25 percent of the total distance from the top leading edge is the CG.
The instructions call for 22 ounces of lead on the fire wall. I moved the weight to the front inside of the cowl. The distance forward, 5 inches,allowed me the cut the total weight in half.
The plane flies like an angel when balanced using a OS 90 FS.
"KLUTZ" the Magnificent
My Feedback: (33)
QC, CANADA
Thanks for your helpful explanation,
I also was a little worried because my stearman's tail is heavy, I was even thinking about overpowering the plane with an OS 1.20,
but now that you tell me that yours flies like an angel I will try to do exactly as you did,
thanks again for your promptly answer,
Humberto
Humberto
