C.G. Ultimate Biplane >
Old 03-20-2003 | 06:49 PM
My Feedback: (84)
Default C.G. Ultimate Biplane
Hey all! Have a question for ya. I bought a C.G. Ultimate from J J Freestyle a while back. We can't figure out what the correct center of gravity is supposed to be. Do any of you guys know the answer to this dilema and would be willing to share the answer with us? Thanks a million.
Clint
Question:
What is the correct center of gravity of the Carol Goldberg Ultimate Biplane?
Old 03-23-2003 | 08:20 PM
Default C.G. Ultimate Biplane "CG"
Hi, Sorry to see nobody has answered your question yet.
The CG on the Carl Goldberg Ultimate is 1 7/8 to 2 7/8 inches from the leading edge of the bottom wing. I set mine to the middle of this range and it fly's well.
Old 03-24-2003 | 03:34 AM
My Feedback: (84)
Finally, an answer to my dilema!! Thank you SO much!
What engine did you use? Will a 120 4-Stroke work okay?
Clint
Old 03-24-2003 | 04:47 AM
My Feedback: (50)
I'm sure it will fly just fine with an 120 fs.
Old 03-24-2003 | 05:49 AM
Default CG Ultimate
I use a 91fx and it has great vertical.
I've heard where alot of flyers use the 120 4C with outstanding results but the front of the fuse may need to be reinforced. You may want to do a search on here in the Kit Bulding forum and see if you can find out what should be done.
Old 03-24-2003 | 08:00 PM
Mine weighs 8.75 lb with a Saito 120. I balanced it at the most aft position for honest flying characteristics. If a 120 is used, you'll have to move some gear aft. My Rx, batt, and servos are all aft of the lower wing TE.
Old 03-24-2003 | 08:42 PM
My Feedback: (84)
Thanks for all the help everyone!! For you guys that used the 120 4-stroke, did you have to reinforce yourfirewall?
Clint
