 Elder40_tank location >
Old 10-05-2007 | 12:36 PM
Don41's Avatar
Default Elder40_tank location
I'm building the Elder40 and using a Saito 56 mounted upside down as called for. I mounted the tank as low as I could but the tank's fuel outlet (Dubro) will be about 3/8" above the centerline of the needle valve. I'm thinking that the taildragger configuration will probably compensate but I still get the feeling that I might get fuel drip.
Do you fellows think this will be a problem or am I just being paranoid?
Old 10-05-2007 | 04:34 PM
Default RE: Elder40_tank location
Paranoid!
Old 10-05-2007 | 04:53 PM
Don41's Avatar
Chuckle. That's what I like, a man of few words.
