Servos for my stinger 120???
PA
I was thinking of using Futaba S3010 High Torque servos all the way around on my new Stinger 120 kit. What would you recommend for a 1/4 scale bird in the 14lb range? I was also planning on mounting the servos for the elevator and rudder on the side of the fuselage down at the tail. I was going to connect everything with the Dubro Heavy Duty Control Horn System. Sound like a good or bad idea to you guys????? Let me know how you set your big birds up and pictures would be awesome too for show and tell.
My Feedback: (7)
As to mounting servos in the tail, I recommend you hold off on that untill you get the structure basically completed, then do a trial balance to see what effect addng a bunch of weight to the tail will do. My guess is that you will not go that option, but check it out before making a decision.
