GP Dazzler
MO
I fly 2 GP Dazzlers (kits). One with a OS 46FX and another with a OS 46SF. The SF powered aircraft weighs 4lb 2 oz and the FX weighs 2 oz more. I never slanted the outside of the ailerons. They are straight, the inside of the ailerons are slanted per the instructions. The landing gear wires are a little soft so once a year I tow them back in, no problem. Use hard balsa on the turtleback stringer, soft will break easy if pick up the plane with stron grip. Good luck, great kit.
build the rudder one in. bigger & elevator 1/2 in. bigger to make the "V" cut wider so it allows more rudder turn, dont be afraid of the extra weight since it will need lead on the tail even with the 46FX´.
