CG bipe cowl problem >
Old 04-25-2003 | 03:08 PM
Default CG bipe cowl problem
I am building the kit version af CG ultimate. The cowl and the wheel pants are fiberglass with something called spectra "gel' or something like that. I am at work so I can't read the box. But the cowl has several hairline cracks and chipped areas which need to be filled in. What should I use?
Thanks in advance
Old 04-26-2003 | 06:39 PM
Call CG, complain about it and they will send you a new one.
