 micro beads >
micro beads
micro beads
Old 03-26-2008 | 09:37 PM
Default micro beads
Need these to complete my Stinson. Can anyone help on where to order?
Old 03-26-2008 | 10:03 PM
iron eagel's Avatar
Default RE: micro beads
Search for microballoons I found this:
http://www.fiberglasssupply.com/Prod...s/fillers.html
Old 03-26-2008 | 10:41 PM
huck1199's Avatar
Look for micro balloons
Old 03-26-2008 | 10:42 PM
Dorsal's Avatar
My Feedback: (17)
http://www.monokote.com/accys/topr1090.html
http://www.hobbylinc.com/htm/top/toptopr1090.htm
Old 03-27-2008 | 02:23 PM
SKYHI1's Avatar
Try these.
http://www3.towerhobbies.com/cgi-bin...&I=LXHZ15&P=ML
I like this product.
Good luck
Frank
Old 03-27-2008 | 02:36 PM
They are available in two forms, maybe more. The fiberglass ones (result in a white mix when used with epoxy) and the phenolic ones which result in a brown color when mixed. Both seem to work equally well.
Old 03-27-2008 | 07:33 PM
Hay!! Thank you all. I think that if I could take my head out of that place where the sun doesn't shine I could come up with a lot of info for myself. But here is another one for someone to answer. Had an old raddle can of Ultracoat paint. It was enamel and I started to paint My Giant Spacewalker wings. You guest it, The paint is not fuel proof. Is there a covercoat that can be sprayed over the enamal to make it fuel proof? Or do I tear the fabric off and cover it again? A job I don't want to unless I really have to. Haven't called any paint company yet. But someone out there has screwed like this before me and has an answer.(maybe)
Old 03-27-2008 | 08:13 PM
iron eagel's Avatar
I heard a lot of scale guys use a clear varnish or poly finish to fuel proof finishes that can not take fuel.
