how big of gap before I seal the hinges?
IN
I've had my hog bipe on hold for about 2 months out of hinging frustration. First I did CA, and I got the feeling it didn't look like it wicked in right... I tested and was right, pulled 2 ailerons out. Redid them, and got them in good. I was nice and careful to make sure I didn't have much gap. So little in fact that I didn't have enough throw because of the rounded shape of the aileron. I thought about sanding them to a point, but I figured that SIG knew would happen, so why should I think about it?
After that I decided to go with dubro hinges. I've got about a 1/8th inch gap now, but pleanty of throw available this time. Am I going to need to seal these suckers?
Nads:
The plane looks sharp, specially the head rest.
But yes, do seal the gaps. At the speed the Hog Bipe will fly you might never have a problem without sealing them, but the control response will be better with the seal.
Bill.
Bill.
My Feedback: (40)
IN
For future reference, you want NO GAP....I typically sand the hinge area to a point, maybe with about 1/16 flat or less. By sanding to a point and recessing the hinges, you can get FULL deflection.
"Ideally", you want no gap. However, especially in the case of CA hinges, it is better to have a slight gap and seal it than to put too much undue stress on the hinges.
Gap seal question: Is it better to form a "pleat" of covering and attach it to both sides of the gap, or use a flat strip and attach it to only the leading side?
Charlie P.:
If you secure one sealing flap on the forward side only it tends to flutter all by itself. I have, however, seen loose flaps installed on both sides of the gap (or top and bottom) working nicely. But they tend to tear/separate from the forward surface where they are secured.
They do look good when they are new, and if you don't mind replacing them every now and then, go for it. Just don't do it on one side only.
Bill.
Bill.
My Feedback: (40)
IN
It has been quite a while since I have used CA hinges......I agree you need to have some stress relief there, so IDEALLY no gap. With the Robart hinges (and all similar to) you can achieve NO GAP.
