goldberg ultimate weight? >
Old 05-20-2003 | 04:27 PM
rwg
Default goldberg ultimate weight?
i'm building a goldberg ultimate kit with a magnum 120 4 stroke. i'm also doing some of the modifications to stengthen fire wall etc. to handle the engine. aluminum landing gear, 2 aileron servos, 2elevator servos. whats this plane going to weigh when done. all you guys with ultimates tell me what your ultimates weigh and how you like the plane. mines getting close to flying and i'm getting nervous this is the first kit ive built and it's turning out so good it's scarry!
Old 05-20-2003 | 05:16 PM
tonyc's Avatar
I don't have mine done yet! It's ready to cover so its close. I built this plane and at the same time I scratch built a larger one 15% bigger to fly with a larger motor. Both are in the covering stage right now. I will post a weight as soon as I get it done.
I did what you did, following Harry Higgleys Bipe book.
I have seen post all over the board for weight on this plane. Anywhere from 8 1/2 to 11 lbs.
I hope to come in at about 10 lbs on the CG Ultimate and perhaps 12 1/2 lbs on the bigger one. The bigger one has 4 servos in the wings and two for the elevator. It will use the Moki 180 for power.
tonyc
Old 05-22-2003 | 12:11 AM
Mine came in at either 9 1/4 or 9 1/2 lbs.....too lazy to go open the shop and look in the log book to be exact. ASP 108 with Slimline Pitts muffler, APC 14x10 prop, Monokote except for glass cowl and pants, aluminum gear, two aileron servos, and one each on elevator, rudder, and throttle. No lead required to balance. This plane is nine years old and flies very nicely.
Clair
Old 05-22-2003 | 07:18 PM
Sprink's Avatar
10 3/4 lbs. YS 120 FZ for power. No need to strengthen the firewall over what is in the instructions for a Magnum 120. I only put some tiangular support on mine.
Mine is too heavy, really should aim for under 10 lbs to get a really good flyer.
If you do a search on this site there are plenty of threads on the Ultimate, it is a popular plane.
