Reload this Page >
Pavel Bosak Jet Trainer Build Thread RCM 972
Old 03-14-2009, 03:44 AM
eyeofra1678
Default RE: Pavel Bosak Jet Trainer Build Thread RCM 972
The nose black was pepet for sanding. F-3a were added. A 3/16 sheet was whetted and installed then cut and sanded
ID:	1157318   Click image for larger version
ID:	1157319   Click image for larger version
ID:	1157320   Click image for larger version
ID:	1157321   Click image for larger version
Old 03-15-2009, 03:08 AM
eyeofra1678
Nose was sanded to shape. (what a job that was) 3/16 top deck was sanded to shape. I then add the nose to the fuselage and clapped it. And know on to the hatch 1/64 pay was used add f-1a and f-2a. 3/16 was add to the sides and top thin sanded. I well use the belt sander to get the shape I need when I get up.
ID:	1157993   Click image for larger version
ID:	1157994   Click image for larger version
ID:	1157995   Click image for larger version
ID:	1157996   Click image for larger version
ID:	1157997   Click image for larger version
ID:	1157998   Click image for larger version
ID:	1157999   Click image for larger version
Old 03-16-2009, 03:10 AM
eyeofra1678
O.K I got the hitch sanded whith the belt sander I then test fet it on the fuselage jest a bet more sanding to do but that well be for later. Fetted the V. fin and mad a inline cut to help with lining up the v. fin later on. And the ruder rod caseing as been added[8D]
ID:	1158915   Click image for larger version
ID:	1158916   Click image for larger version
ID:	1158917   Click image for larger version
ID:	1158918   Click image for larger version
Old 03-24-2009, 12:10 AM
eyeofra1678
Nose gare block CAed and braced in to place. F-2 was cut to let the gare up into the fuselage. The fiul thank has been put together
ID:	1164947   Click image for larger version
ID:	1164948   Click image for larger version
ID:	1164949   Click image for larger version
ID:	1164950   Click image for larger version
ID:	1164951   Click image for larger version
ID:	1164952   Click image for larger version
ID:	1164953   Click image for larger version
Old 03-24-2009, 01:33 AM
andrew66
andrew66's Avatar
very nice work! I love that retract system. I wonder how big of model that it will work on?
