AMR Giant Stick 50
rustypep (04-12-2024)
#232
RE: AMR Giant Stick 50
ORIGINAL: Aircraft Modelers Research Inc
New picture from a customer
when that guy slaps those twin 30's on that bird and posts a video it might push me over the edge to buy one
great stuff AMR #1
#234
So far I mainly have all glow plains. I have only built two gas powered planes and like them a lot. I have never flown any kind of twin before because I have always heard they are a lot more trickier if an engine goes out and getting glow engines to synch just right is kind of a challenge. I was just wondering, are gas engines any more reliable as far putting the on a twin engine plane? I know my OS 55 gt and DA100 I have now seem every bit as reliable if not more than a lot of my glow engines. Have you experienced an engine out on this twin engine stick and do you know how it handles flying on just one engine. I know if one engine goes out its best to kill the other one as soon as you can and just try to glide it in.
thanks,
David
thanks,
David
#235
Michel, will the twin firewalls accept a DLE55? I live at 6,000 feet and we need extra power. I've got a DLE111 on your Stick85 and it could use more so I'd like to build the twin and put DLE55's on it. Thanks, Jerry.
#236
QC, CANADA
You will to move the engine box a little bit to have more prop clearance. Those engine box are very strong, we already have those parts laser cut, if someone want to modify his stick, or install 3 engine... like 20 or 30cc.
#241
Ordered my Twin Stick. Michel mentioned the firewalls are 4.25 x 4.25 in case any of you are interested. Should fit a DLE55 using a three blade prop. I'm converting mine to tri gear.
#246
Got my Twin Stick fuse built and rough sanded when I noticed there doesn't seem to be slot for the servo wires for the elevators. The bulkhead at the front of the rudder looks to be blocking all access for a servo wire. Did I miss something in the build? Jerry.
#250
OH
i have the 50cc stick and ready to instal the motor . i am using the DLE 55 . i see that my carb. is in the center on the back witch means i will have to build a platform of some kind in side the plane to mount the throttle servo . has any one done this ? if so can some one post picks of what they have done ? thanks karl
