Prop for os-160ft
Hello I recently purchased a XOAR prop for my cub Im running an OS 160ft my problem with the prop is it is too thick for me to get my prop nut on ... Does anyone have any suggestions as what to use... Thanks Carl
Maybe I should explain further I have dubro prop nut that I wanted to use but because of the thickness of the prop I can't use it, I was hoping maybe a Zinger or Master Airscrew would work..... Thanks Carl
OK, So what your saying is that the Dubro prop nut won't fit as purchased, that I need to ream the prop and use part of the OS retaining nut and screw the prop nut to the retaining nut ,I thought about this but have'nt seen anything online that will mate the two together???
