Great Planes Extra 300s .60 size
Hello all, I just bought the .60 size kit and I'm looking for feed back from anyone who has experience with the plane. I'm going to put a O.S. 91 FX in the front end and also use two servos on the elevator. Any comments or what to look out for would greatly help.
OH
Hi Bob, i built one with a 90 st pitts muffler covered in fabric wt 8.5lbs a little heavy but had very good vertical, i used the y single servo on the elevator all 3oo3 servos, was my first low wing very easy to fly, would beef up the landing gear area & buy a glass cowl the plastic one cracked in many areas after a few flights good luck Jeff
Bob, the GP 60 Extra 300 is one of my all-time favorite planes. I had more than 200 flights on mine over 3 seasons, when I stupidly put it in about a month ago.
I powered it w/ a 91 four-stroke engine the first season, but switched to 120 four-stroke later on. The larger engine really brought out the Extra's great aerobatic potential. Your 91 FX should be an excellent match.
For a full review I wrote go to: http://webpages.charter.net/rcfu/Kit...Extra300S.html
I've built two, the first one lost in a mid-air. I pretty much followed the plans and used all the stock materials.
To form the rounded forward fuselage, wet the plywood, then bent it around a gallon paint can. Hold it in place on the can with rubber bands and let it dry overnight. It will then fit on the formers just right.
Another change I made was to apply the wing center sheeting in one long piece instead of making separate left/right halves. You will have no problem bending it since there is very little dihedral. This makes a smoother joint and you won't need any fiberglass tape.
Mine weighs 7 1/2 pounds and can hover with a 91 four stroke.
Tom
Tom
RE: Great Planes Extra 300s .60 size
hi gang
once had the gp 300 and it was a great flyer under power. lose power and you have
a crash on your hands, lost my when I flew too long and ran out of fuel, down she
came. do not try a low throttle glide in landing approach. you must keep some power
on until touch down. at least this was my experience.
good luck with yours.
pt19 flyer
pt19 flyer
Hey guys :
This kit has been discontinued for a long time, but I would like to build one.
The only thing i'm looking for are the die-cut patterns plans. Does anyone have it or knows where I can find it ? I would be very happy to find it.
Thanks from france
Thanks from france
