Bud nosen giant trainer fans..anyone out there?
RE: Bud nosen giant trainer fans..anyone out there?
heres where you need to start reading, right on RCU !
warning though, once you have a little success at it, you will get pulled to the dark side! hahahah
http://www.rcuniverse.com/forum/forumid_92/tt.htm
A couple new pics. Fitting the wing to the slightly changed wing saddle..Moved wing ahead a tiny bit, wing corrections and finishing moving forward. Getting ready to build some wing struts also.
I took a set of gear from a buddies GP pt-17, They had split a little so he replaced them, I just epoxied the outer covering back onto the aluminum strut. I cut them in half at the center of the aluminum cross bar....and screwed them into plywood landing gear block I installed, they look pretty good on there I think.
http://www3.towerhobbies.com/cgi-bin...?&I=LXJUM0&P=7
#31
Instead of a Mr Mulligan, I think you have come up with a MISSMULLLIGAN. Looks kinda cool. Quite creative of you.
#33
haven't ordered it yet, but probably one of the bigger ohio products tailwheels.
I told my buddy from some angles the thing looks like his dang CANTZ italian (CRASH) bomber !!! He just laughed ...
I think I am going to make some dummy exhausts pipes for the sides of the cowl, that way it will hide some of the flatness of the fuselage.
#34
IA
bump - getting ready to maiden my Nosen Trainer that I built 15 years ago.
Wondering how you came out with this build? did you finish? did it fly?
#35
I am slowly working on it and about four other things, I get bad at that..been covering the tail. I hop around so as not to get burn't out.
PLEASE get pics and possibly video of your plane. I would love to see it. ! And thanks for taking the time to read the thread and ask about the project...Its slowly moving forward.
#36
Well I stumbled back onto the Nosen trainer after a few other side projects..I went ahead and started the bomb drop/parachuter hatch. Thanks to a thread over on Bruce Tharpe http://www.btemodels.com/sfk_candydrop.html .,... I got something similar built.
I built a location in the bottom of the trainer, then a separate unit to drop in (LOOKS LIKE AN OUTHOUSE)
No control rods or cables yet but its getting closer !
#38
I glued on the plywood for the tail wheel mount, and the rear hatch built, I might need to mount the radio and battery in the tail to offset the large motor and long nose of the plane. A little dent filling here and there along the way. I should be working more on the wing finish, but I haven't got to it as of yet.
#39
I did manage to sand the nose hood a little today and add a tiny bit more filler..put it on sand it off ! when does it end !
#40
Well the nose is a little more rounded, more flaws sanded away....and I have some paint on the bomb/parachuter drop box. I don't recall if I had the servo mounted and control rods on last time either? I will have to review my own thread!
#41
ALL COVERED FINALLY!
I am going to do a pt17 kind of scheme, its just a matter of drawing it out, and starting to work on it. My goodness the wing is huge ...Its covered with I believe is called ceconite, http://www.aircraftspruce.com/catalo...nitefabric.php
It will be hand painted with acrylic hobby paints, then clear coated.
#42
Well I am trying to decide how to paint the windows on my pt17 schemed plane...here are a few ideas so far, do you prefer one over the other?
#44
I am still painting, but I decided to get the tail glued on before painting it, I am also working on the tail bracing wires. I have the top ones soldered up, Now on to the bottom!
1422
1422
#45
How about a little wing action? mostly painted with a foam brush. The roundel edges were done with a nice brush that holds a clean line. I am not really trying for a perfect opaque paint job as I like my planes looking well worn..and I will be weathering and highlighting detail for fun and effect !
1444
1444
#46
I've been pushing hard on the weathering and detail on the finish, some brushed highlights shadows, airbrushing , even a little chalk work and panel line action. I really like it when planes look like they have been worked hard. It also gives a nice (stand ten foot back) scale finish as well. hopefully if things go well I could be clearing it tonight also. I am just going to use 4 dollar cans of rustoleaum clear. this baby will be poulan gas powered..so the glow fuel is not an issue. its coming along nice though...Hopefully I will get to a point to take some pics tonight or tomorrow.
heres my D7 from a couple years ago..my last paint project.
1500
1500
#48
A few more pics! Have the wheels I plan on using finally ,mounted, and she is up on the gear for good now !
#49
I have really tried to hide the dead flat surfaces with a few panel lines and airbrush,chalking..I think it looks much better than a smooth flawless color..But thats just me.
1564
1564
#50
You have inspired me to get my Nosen trainier out of the basement, make the needed repairs and get her back in the air.
Not sure what engne I will use... the old .60 just didn't do it.
N.C. Flyer (03-09-2020)
