ISC Int.  ARC  any experience?? >
Old 03-27-2002 | 03:39 PM
Default ISC Int. ARC any experience??
Anyone with experience building and finishing one of these kits..any advice..thanks wc
Old 03-27-2002 | 04:58 PM
rev
Default ISC
I have the extra300 arc. It is a good built arc but has some bad flight char. It will tip stall in a hard turn at any speed and is a fireball to land.
Old 03-28-2002 | 04:15 AM
Can anything be changed while building the arc to help prevent tipstall..thanks wc
Old 03-28-2002 | 01:16 PM
rev
Just keep it as light as you can. :spinnyeye
Old 03-28-2002 | 01:46 PM
ROGER RUSSELL's Avatar
My Feedback: (12)
Default ISC STAUDACHER
I have the ISC Staudacher (see pic to left) very good arc, been flying for about a year, 50 + flights with G45 up front. Yes this bird tip stalls too! Just read in Model Airplane News??? about someone experimenting with putting on straight pieces of wood at the tips or the wing about 3/4" bigger then the tip size. They said it improved the tip stalls and allowed them to land slower. They said it pushed more air over the ailerons by forcing it back on the control surface, I might even try this too??
Old 03-28-2002 | 07:25 PM
LuvBipes's Avatar
Before, committing to any major wing modifications, try raising both ailerons. Yes, I meant RAISING them - about 1 to 1.5 turns on the clevis should do. This has the effect of creating washout at the tips, thereby, making the wing root stall before the tips do.
Old 04-01-2002 | 09:16 PM
My Feedback: (13)
Default tip stall?
I am flying the Extra 300 with YS 120 at about 12 pounds, and I can bring it in really slow. It lands great. Mine is easy to fly and has no bad habits. It is one of my favorites. That being said another club member had one with an OS 160 twin and he said his was a slug. His was heavier than mine also.
Old 04-01-2002 | 10:03 PM
Thanks for the reply...How was this kit to build? How are directions, etc? I have not seen this company, ISC INT, advertised any recently..I wonder if they are still in business. I think that they were located in Champaign, Ill..Thanks for reply
Old 04-01-2002 | 11:58 PM
My Feedback: (13)
Default ISC
I didn't build mine, so can't comment. Horizon now handles ISC.
Old 05-01-2002 | 01:07 PM
Default ISC Int Tail Feathers??
The tail feathers on this kit are not airfoiled, can that be changed, if so how and will it help flight, or better left alone?
