Push rod linkages
Hello,
I just bought a new built plane and the builder used the screw down connectors to attach the wire from the push rods to the servos. I usually use a cleavis to connect to the servo.
Are these screw down connects good?
It seeams like they could slip and cause unexpected problems.
NM
skyfoxx
Ive used these on trainers ,for all the surfaces and have never had one fail, although I have read of several failures from various sources.
I make checking them part of my ground check before each flight
I would however not recommend them for a faster more aerobatic plane . even though Ive seen clevises fail also !!!
Highlander
Highlander
Foxx:
I wont use them for operating a control surface except with "Pull-pull" systems.
And yes, definitely cut a flat for the setscrews. Never had one come loose with a flat.
Without a flat ANY setscrew has a greater probability of coming loose.
Bill.
Bill.
