Cub Struts
My Feedback: (13)
NC
RE: Cub Struts
Spencer,
Go to www.thecubden.org and there are some instructions on how to make some for a 1/4 scale model out of alluminium. The can be left attached and fold down when not in use. I think you could make these work for a smaller plane.
Good luck
Alan
Good luck
Alan
My Feedback: (15)
CA
RE: Cub Struts
On the Goldberg Cub they are not structural, just for looks... but the Cub looks funny without them in my opinion. The Hardware suppiled in the kit is junk(plastic crap), they just use 2 each side Spruce (I think) 1/2"X1/4" by about 22 inches long rectangle stock you are supposed to round off the corners after you create the "V" shape. It attaches to two points under each wing and one point near where the rear landing gear hinge is on a real Cub. Just cover them or paint them but attaching them is up to you. I am at that point on my Cub and am going to make them stay on the airplane with small metal brackets screwed to the 3 points on each wing, I did this before and it worked great. I did add support inside the wings that is much beefier than plans call for and the brass threaded inserts (4-40) in the wing mounts so I can fly with them attached. I am also going to add the smaller central supports if I can make them look good. I would post pics but I havent built them just yet... they are lying on the bench with all the attachment hardware though . Do you have the original plans? doesnt sound like he gave them to you but I bet somebody where you fly has some! might help out but they are very simple! if you look under each wing 18 1/4" from the cabin side or 20 3/4 from CL (measured for you) there might be the mounting holes.Let us know how you come out on them ok?
CA
RE: Cub Struts
yeah i have the plans and i will take a look at them and i did mount a piece to for the struts to go into i put 2-56 blind nuts in there so i can use cap head screws i will probably use a swivel on the wing part and make the part that attaches to the fuse solid metal as for parts i have some air foiled aluminum if that doesn't pan out i will go for the wood ones and try that.
My Feedback: (15)
CA
RE: Cub Struts
Cant go wrong with the airfoil shaped struts! the measurements I gave are for the full span wings (should have mentioned that) if the mounts are there then it should be pretty easy to get accomplished. Let us know how it works for you ok?
CA
RE: Cub Struts
i will for sure im going to get some pictures taken soon and ill do a before and after. this bird is gonna be nice im covering it old school with solartex!!
My Feedback: (15)
CA
RE: Cub Struts
I did my first one with solartex and sprayed it Cub yellow and it was gorgeous! and not heavy with 3 cans of paint on her. I am doing this bird with the Olive Drab Monokote with Dove Gray on the bottom and invasion stripes, sort of scale as I am not going to try to do the full L-4 treatment on the Goldberg Cub but it will look good I am hoping. I am running a Saito .80 twin 4 stroke and I went nuts and fabbed my own scale (close anyway) landing gear for it, I am close to starting the cover job right after I build the struts hopefully tomorrow. Couple of pics...
CA
RE: Cub Struts
man that suspension set up you have there is pretty sweet. im not goin super crazy scale with it but i want it to look good. my motor setup is an os 70 ultimate with a 16 O.Z. fuel tank. i should get about 25 mins of flight time on about half throttle. The motor runs with a ton of power so it should be good. and if i feel the need to deck it out i can do it later but this plane will probably end up on floats!
RE: Cub Struts
I just bought a set of these from Horizon, http://www.horizonhobby.com/Products...ProdID=HAN4035 . They are for the Piper Pawnee 40 size. They are about 20 inches long and have all the attach hardware.
