help with wing jigs
I am building a pt-20 from great planes and it comes with a wing jig set to set the washout but how does it sit on this???? It look like in the picture it sits inside of the opening but the cord on the wing is to wide and it will not sit inside of it. Any help would be great. Here is a copy of the manual the will not let me copy a pic out of it. Page 32 shows what I am talking about.
twostroke,
I have not built a PT-20; however, the attached schematics show what I understand from reading the manual:
The central rib rests flat over the table, as well as both templates.
The wingtips rest over the top of the templates, which are placed vertically (following the angle of the top).
The trailing edge of the wingtips should be higher than the leading edges, while both edges are equally high for the central rib.
If less dihedral is desired (sport version), the template is cut and overlapped, in order to make them shorter, while the washout remains the same.
Best luck with the building of the kit!
That I understand, it is that the wing does not fit inside of the tabs on the jig the wing is to wide. if the wind was not as wide it would fit in there fine but right now if i put the leading edge in it the trailing end has to sit up on top of the tab.
I see.
As the reason of the jig is to keep the same height and twist angle of the wing tips, you can just eliminate the tab of the leading edge.
That modification will not affect either the height or the twist angle.
Did you verify that the actual chord of your wing is as specified in the plan?
According to Tower specs, it should be close to 9-3/4".
My first kit was a PT-60. It had the same type of washout jigs. I was confused about them so I talked to my instructor about washout and how to finish building my wing. He gave me a basic explanation of washout and then told me to just build the wing straight (zero washout). He said the big flat bottom wing really didn't need the washout and that he thought it would be easier to get the two wings more alike if I kept them as flat as possible on the building surface.
IL
When I built my PT-40 I used the jigs and built the washout into the wing. Regardless of how effective it is, it does look cool with the washout in there and is not that hard to do. I tack glued the jigs to the wing tips and held the jigs down to the table with sandbags just like it shows in the manual. Once you have your sheeting in place you just carefully break the jigs off of the wingtips. It works good.
Did you build the A wing or the B wing?
Banned
twostroke,
You did not say how much the chord is too long to fit in.
It is odd that the manufacturer would supply a jig that is too short.
I would build the washout. The model without washout flys nicely until it approaches the stalling speed. That is when you will appreciate the washout. Many fliers never come close to the stalling speed Like some fellows fly at full throttle all the time.
Half a penny's worth.
Zor
ORIGINAL: Zor
twostroke,
Zor
twostroke,
Zor
Banned
Its about a quarter inch to long and thats why I ask about it here I though something cant be right here with the kit being from great plane usally there kits are pretty good and instruction are very good!!!
Make it 8.75 ; the difference is only 53 thou ( 53 / 1000 of an inch ).
Your chord is about 1/4" too long. That is 250 / 1000 of an inch.
What is your actual chord on the drawings?
What is your chord measured on the wing assembly ?
What is the distance measured on the jigs ?
I know you assembled the wing over the drawing but please make actual measurements.
I am just puzzled and interested if you do not mind.
Perhaps they have put in the kit jigs for another model by packaging error .
Zor
ORIGINAL: Zor
ORIGINAL: Zor
I have calculated you chord to be 8.697 inches. I do not have the drawings.
Your chord is about 1/4'' too long. That is 250 / 1000 of an inch.
Zor
Zor
Banned
I checked the cord and it is right about 9'' the opening on the jig is about 8 7/8'' so i notched the jig to fit. I also checked the number on the piece of stock it came out of to make sure it was for the pt-20 and it is correct. Strange that no one else has run into this with this model.
OK for the 9" and 8 7/8". That was on the wing and jig.
What is the drawing calling for?
Zor
Banned
ORIGINAL: Zor
It is possible that someone else had the same situation but did not mention it.
OK for the 9'' and 8 7/8''. That was on the wing and jig.
Zor
Zor
Perhaps you missed post #14.
I still wonder what the drawing was showing as the chord.
Could you please let us know the measured chord on the drawing.
Many thanks,
Zor
