Who Makes TowerKote?
Is it an exact copy of Monokote, Ultrakote or something entirely different (like ChinaKote). At half the cost of anything else, the price is appealing but it is too good to be true it seems to me.
It may be equal to Top Flite Econokote. It is definitely NOT acopy of Monokote or Ultracote.
It is a low temperature covering and many say it is not fuel proof for glow powered models. I've used it to patch an ARF trainer. One combat pilot I know uses it on foam fuselages and wings. He does not worry much about fuel proofing since combat planes usually have short lives.
MO
When You first put it on it looks ok. Will not stand up to years of use or even hanging in the hanger! I have a plane that Has not been flown in three years (trainer) and the Towerkote is slowly comming loose.
Banned
ORIGINAL: SpinnerRow
Did you contact Towers?
ORIGINAL: Zor
Looks like no one knows ''Who Makes TowerKote ?''
But.. I got my answer. I won't be buying a roll of it.
My Feedback: (14)
ORIGINAL: MikeL
The manufacturer probably changes from time to time, depending on who will do it for the lowest price. It's a crappy product.
I knew that if I looked long and hard enough that we would agree on something. And we do.
I covered a Phaeton biplane (original Balsa USA model) with Econokote. Within a year, fuel had crept under the covering virtually all over the model that was in the propeller slipstream. I never had this problem at all when using Super Monokote or Oracover (Ultracote).
Ed Cregger
Banned
No, I kinda figured people here would know more than a sales guy on the phone.
ORIGINAL: Zor
So . . . my question "Did you contact Towers?".
It is unlikely that the modeler know who are the manufacturers as many hobby products are made by subcontracts.
I have noticed, over the years, that most manufacturers do not have websites and rely on importers and distributors to handle any inquiries.
Of course the importers and distrinutors have little knowledge of the products manufacturing.
So I fully agree with you but it is unfortunate that we are so restricted to the products knowledge.
Finishing models, I have been a "fabric and genuine aircraft dope" modeler. I like building as much as flying and I like a finish like the full size "tube or wood and fabric" finish. I consider the dope as being the best by far adhesive for the fabric and its long life characteristics and properties. The reason why many full size airplanes are finished with fabric and dope. None to my knowledge are using "iron on plastic films".
Yes I recognize that Ceconite (spelling ??), polyester and nylon are plastics but they are not ironed on with poorly adhesive media and do not tear easily.
I also recognize that fabric and dope is not a practical and economical finish for pre-fabricated models (ARF and RTF). These models are made under highly competitive markets and made to be replaced often. The health of the industry is at stake.
Zor
My Feedback: (8)
I don't know who makes it either, but I had a good experence when using it, easy to apply, shrinks nice and stays put. The fuel proof issue, I can't comment, the seams on my planes are usually pretty tight and I saw no ill effect from oil or glow fuel residue. I just stick to mono or ultra if I'm going plastic on a plane, for fabric, I do solartex or koverall and dope.
It is Econokote, and it is sold as a cover it all product as it is low heat so it can be used over foam without melting. It is not stiff like Monokote so it is not great for adding strength.
Banned
ORIGINAL: ramboy
The label that comes on the roll of Towerkote says it is fuel proof.
What seems to be reflected in the comments is that glow fuel penetrates at the edges of the sheeting and I conclude that the adhesive is not so fuel proof as the clear plastic surface.
Perhaps someone can elaborate on this.
Zor
My Feedback: (16)
I built or assembled a Foam/balsa sheet plane in 2000 and covered with TowerKote. I still have it and fuel has not bothered anything about it. - not even the trim pieces.
It is made by http://www.generalformulations.com/ in Sparta MI 49345
My Feedback: (14)
ORIGINAL: planebuilder66
My seams are tight and were sealed using K&B Superpoxy clear. This same sealing technique never caused me a problem when using Super Monokote or Oracover/Ultracote. I was really dismayed because I loved that Phaeton Biplane. I wish they would offer the original kit once again.
I don't know who manufactures Econokote/Towerkote (I was told by Tower that they were the same product). I do agree that it goes on like a dream and is an otherwise great covering. Who knows, maybe my Econokote was not typical of the product produced later.
Ed Cregger
