*** Ultra Sport Brotherhood ***
#2930
NY
It flew it but had very little vertical. However, mine was already old and well used when it went into my 1000 20 years ago so if your has less time on it, it might do the job a lot better.
i expect the low time Saito 150 to be a different story though! Im sure i will pay for that added power in glow fuel unfortunately. if i could fit a DLE30 in the nose I would but as i don't feel like cutting it up for a facelift I'm not inclined to try. prop clearance might be an issue as well but if i were building a new one, that would be my engine of choice.
#2931
How about a NGH 26cc or Evolution 20cc gas enginesfor the Ultrasport 1000? These have front carbs and would not require a bit tear up of the cowl except for the bulky gas carb.
#2933
My Feedback: (12)
Here's the OS FS-120 I have. Just needs a good cleaning. I had to have it because I like the dual rocker covers. The muffler seems tiny for it though. From the sounds of it, it doesn't have enough power for the US 1000.
I have a friends US1000 in my basement for several months now. He's talking about getting out of the hobby so I may have work out a deal with him on it. Anybody ever put two 60 size 2-strokes on a US1000?
#2934
NY
Exact engine i have. It depends on what kind of performance your looking to get out of the plane. Its not a 3D type plane. If you want a "Sunday flyer" type that engine will get the job done. Don't forget there is a reason OS went to the Surpass line, as they put out at least 20% more power.
#2936
NY
My engine has no muffler, just the header pipe.
Sounded fine that way too so i never bothered to check to see if it was even supposed to have one!
Going to make a base and stand for it and use as paperweight at my office as there are no parts available for it not too mention it not worth rebuilding...
#2937
My Feedback: (46)
All this talk about engines on the 1000, I have a 60 size kit I want to build and if I do it will be getting a YS 1.15. We race .40 size warbirds with the 1.15 so I would think it would be the perfect match for the 60 size. I had an old YS 1.20 on my 1000 about 20 years ago and it was good, but not knock your socks good. I think a 1.20 would be the smallest size I would run on the 1000.
#2940
NY
I could get bearings but doubt a ring. With its age its probably due for a piston and cylinder too,.
However the bolt deep in the head by the glow plug has part of a hex key snapped off inside it and I have yet to find a way to remove it so its sits on the bench collecting dust...
#2941
My Feedback: (12)
Frank Bowman use to make piston rings but I heard he retired. Now there someone out of the U.K. that makes them. For a ringed engine a new ring is all you would need to bring it back.
That's too bad about the cylinder head bolt. I use heat to loosen stubborn bolts now. Perhaps mounting the engine in a block and using a drill press to drill the bolt just enough to pop the head off will do the trick.
#2943
NY
i know Frank Bowman retired but was not aware of someone else making replacement rings. Wish i had ordered a few for the current engines i have as i have heard very good things about them!
Also thought about using a drill press with the bolt but i wonder if the allen key is a harder steel and will i be able to drill it. Also if i remove the head of the bolt will i be able to find a replacement?
In the end its an old engine. Will look nice on my desk cleaned up! lol
#2944
You might want to call Tower Hobbies and ask them if their piston ring for the 120 Surpass III is backwards compatible with your pre-Surpass engine: http://www3.towerhobbies.com/cgi-bin...?&I=LXCT33&P=7. Same for the screw set they sell for the 120 Surpass: http://www3.towerhobbies.com/cgi-bin...&I=LXCV57&P=SM. I know a lot of the OS parts are back-wards compatible.
Really the only challenging issue for me is removing the broken bolt.
That is, if you really want to restore that engine in the first place.
#2945
Well I just received a Ultra Sport 1000 NIB unopened kit yesterday, I've been looking for one for quite some time...can't wait to start it, but first I have to finish a Sig Morrisey Bravo that's on my build table. Requesting a number in the brotherhood.
#2946
My Feedback: (7)
I haven't seen any of you guys post something so I very much like to do this for all of us, Well if Great Planes gave us a 60 size Kaos ARF well I think its definitely time to say that Great Planes has now given us wait for it.... Introducing the Great Planes Ultra Sport 40 ARF with retracts for $199.99, I'm so getting one of these I have a Saito 82 GK that needs a home and this plane could very well be the home for this motor I think. Tower Hobbies is showing arriving mid January. Now the wait is on and I'm really digging the color scheme too.
http://www.greatplanes.com/airplanes/gpma1015.html
#2948
Or just spend $119.95 today. http://ecsvr.com/abm/shopexd.asp?id=2330
#2949
Airborne Model Aeropet 50 with shipping: $134
My experience with Great Planes with several models has been good to excellent, but my one and only experience with Airborne/World Models has been very bad. To me, the extra $6 is well worth it.
