Reload this Page >
*** Ultra Sport Brotherhood ***
Old 07-08-2017, 07:36 AM
  #3001
Top_Gunn
Originally Posted by Dan.H
I did the same Joe, went with the flat yard stick across the top and it still flys very good, Ive always heard that kaos wings and ultras should be flat on top.
That's right. All the dihedral in the US 40 and US 60 if built according to the plans is in the bottom of the wing. The top of the wing is flat, but because the thickness tapers, the bottom has some dihedral. Always wondered why the instructions tell you how much to raise the tips when gluing the wing halves together: it's easier to glue them upside-down on a flat board.
Old 07-08-2017, 01:13 PM
  #3002
jrf
My Feedback: (551)
I just re-checked the instructions on the US 60 kit. I calls for 1 1/8" dihedral under each tip. If you do that the top of the wing is definitely not flat.
The original design of the Kaos and the UltraSport called for 2 degrees of dihedral measured at the wing's centerline. The plans for all of the Ultra Sport kits called for dihedral. That spec has be debated and tested by competition pattern flyers (thread in RCG) and the verdict is that it flies best with just a hair more dihedral than originally called for. (2.5 degrees?)
But to each his own. If you like it with reduced dihedral, fine, enjoy. Just don't say it was designed that way. It wasn't.
Old 07-08-2017, 06:09 PM
  #3003
Top_Gunn
You're right. It's close to flat, but not quite. My bad.
Old 07-10-2017, 05:25 AM
  #3004
paladin
My Feedback: (9)
if debating what to do w dihedral I have listed as best I can a short affect of what each does
facts are reducing dihedral will reduce the aileron coupling when rudder is used. it will also make it hold a bank better.
more dihedral will make it settle out to level with less pilot input (the opposite of holding a bank).
I like that when doing stall turns wing overs, and hammer heads I don't have to carry as much aileron to keep the wings level. and in the wind it holds a bank so I can use lift vectoring to set a straight low pass or any pass for that matter, with out being concerned about it settling out.
Joe
Old 07-10-2017, 08:49 AM
  #3005
jrf
My Feedback: (551)
Once again, let me say that you can set up your plane any way you want to. But for reference, in simple terms, here is the reason for the dihedral.
We want an aerobatic airplane to be neutral in all axis. That means that the airplane will continue indefinitely along the path that it was last commanded to follow. Roll it 15 degrees left in level flight then center the controls and the airplane will continue in level flight, in a 15 degree left bank. Raise the nose 45 degrees, release the sticks and the airplane will continue to climb at 45 degrees. The benefit is that any input the pilot gives is followed exactly by the airplane, without having to use a portion of it to correct a deviation from the last input. In level flight, upright, inverted, knife edge or anywhere in between, the airplane should fly straight across the field without further pilot input.
In order to be neutral in roll, low wing airplanes like the Ultra Sport needs some dihedral. Mid-wing airplanes like Edges and Extras need zero dihedral, and high wing airplanes need anhedral. The dihedral and anhedral are the aerodynamic fixes for the problems that gravity creates when the wing is not on the vertical center of gravity of the airplane. And of course the amount of dihedral or anhedral needed for each airplane is different.
By removing the dihedral from a low wing airplane, you make it a bit less stable when flying upright (like flying a high wing airplane inverted), and a bit more stable when flying inverted (like the high winger, right side up). The first half of your rolls will be a bit faster than the second half. Rolling into a turn the airplane will have a tendency to over-rotate. (You have apparently learned to prefer that behavior.)
The Ultra Sport with the called for amount of dihedral and the called for CG, is neutral in roll and will not self level in a turn. It is not neutral in pitch when in knife edge, but that is a whole different discussion.
Old 07-10-2017, 09:06 AM
  #3006
jrf
My Feedback: (551)
With regard to rudder/aileron coupling, yes, the high rudder on the Ultra Sport causes the airplane to roll away from the direction of rudder input. This is a common problem with low wing aircraft. But reducing the dihedral is not the best fix. Try mixing opposite aileron with the rudder. Of course that will screw up the knife edge, so you might want to put the mix on a switch.
Setting up an airplane is always a series of compromises.
Old 07-28-2017, 05:17 AM
  #3007
stuka
My Feedback: (62)
Default Ultra Sport 60 Info
I know this info probably is in the thread somewhere, but it is a lot to read.
I was wondering if anyone has converted one of these to electric. If so what set up did you use? Motor, ESC, battery, and prop.
What air retracts have you guys been using?
Do you guys think it is worth moving the gear out one bay when you retracts as well?
I have been out of the smaller airplanes for a while, but like most of you guys this was my favorite sport plane. My first had spring air retracts with a Supertigre 75 if I remember correctly.
Thanks in advance.
Old 07-28-2017, 06:17 AM
  #3008
Danster_1
Cool Wrecked post #2283 Resurrected
Some years ago, I posted #2283 showing my 1994 Ultra sport 40 after a low speed tip stall whack.
This past winter, I finally resurrected it with a few upgrades, super bright LED's and a 2.4 receiver, she's just like new but for a very slight color mismatch just due to the age of the plane but looks good.
Best part is she's still 100mph plane and flies on a rail, straight as an arrow, I was hoping I didn't screw up the engin alignment, thrust issue when I rebuilt the nose, wings and tail.
was going to downsize a bit but I put the .61SF back in it and it's still my favorite plane of the fleet and back in full service :-)
ID:	2225938   Resurrected.pdf
Old 07-31-2017, 08:01 AM
  #3009
paladin
My Feedback: (9)
Thanks in advance.
depends on what you want to run. we have 2 us60's on turnagy 4260-500 turning 12x8's on 6s, another on turnagy 5045-430 same prop and batteries. everything else I have has retracts so my us60 is fixed gear, but I would recommend spring air when they come back.
Joe
Old 11-24-2017, 11:48 PM
  #3010
RDJeff
Please add me to the Brotherhood! I got my hands on a short kit of the 1000, and so far, I've built the tail feathers, built up the spruce spars, and glued up the fuselage halves. I'll be running a Super Tigre 3250, and I'll be making some custom fuse mounted aluminum landing gear with the back sweep and wheel pants. This ought to be fun!
Old 11-27-2017, 05:36 AM
  #3011
Mikey954rr
Love to hear about this. I am getting ready to start one myself here. Still torturing myself over engine choice. I need it to be gas but where I need to be size wise is stumping me. I too will be putting my lg on the fuse mostly to make more prop clearance and just for simplicity sake. Good luck on your build Jeff and I hope to be following in the next month myself.
Old 11-27-2017, 03:23 PM
  #3012
RDJeff
You're a Honda guy, eh?
Old 01-30-2018, 10:00 AM
  #3013
Danster_1
Smile Can I get a number Please...
Hello, I posted #2283 and #3008 and don't believe I ever got a brotherhood number. My girl is the resurrected Purple Plum, Metallic Green and Chrome top and Purple Plum and yellow tiger striped bottom U.S. 40 size with an O.S. .61 SF in it. I just picked up a Brand New in the box U.S. 1000 for $150 and I am going to put a Saito 1.8 into it, retracts and flaps doing the original 74" version. I am considering the exact same color scheme for big brother. This will be next winters project as I have an F-4U Corsair and Gary Wright E3D in the works for this winter :-)
Thank you, fly on ultra sports, fly on...
Dan Mioduch
Danster_1
Old 01-30-2018, 07:16 PM
  #3014
rglgatortail
My Feedback: (7)
1. Ken Isaac - RCKen
2. Mike Buzzeo - Minnflyer
3. Alex7403
4. Dash008
5. AH1G
6. tschuy
7. MILDBILL-RCU
8. Box car
9. Top Gunn
10. SeaJay
11. Crash Campbell
12. SKYHI1
13. ChuckW
14. RhyanO
15. landeck
16. Ilikebipes
17. airbusdrvr
18. Insanemoondoggie
19. daisy shoot
20. prgonzalez
21. BelAirBob
22. hrrcflyer
23. rastus1
24. tony0707
25. *JCB*
26. Redback
27. bigugly
28. MetallicaJunkie
29. Gordie M
30. Jim_Purcha
31. rcsws
32. jeffsend
33. fireman7875
34. 72
35. ser00
36. Oly
37. cpeisher
38. donzhere
39. SKYHI1
40. kbarko
41. pgilbert
42. rambler53
43. rcjets_63
44. dschroeder
45. Quikturn
46. blueapplepaste
47. green river rc
48. SushiSeeker
49. VCScott
50. FallDownGoBoom
51. ccp10
52. Deadeye
53. Eganwp
54. carlosponti
55. Navy18
56. MineBurg
57. Cdallas2
58. loopyrc
59. Sled
60. Bernard
61. jrbmoto
62. Bubba153
63. Alfredbmor
64. FentonFlyer
65. Sneakywrist
66. BLW
67. smkrcflyer
68. gabarber
69. Amishwarlord
70. JPMacG
71. kamakazie frank
72. RussianFlyer
73. RoyR
74. Red Jeepster
75. Fallingleaf
76. Yukonflier
77. rcjim000
78. goonybird1
79. rglgatortail
80. Latebreaker
81. Tango juliet
82. Saito18
83. hafidy
84. RR24
85. mechdrew
86. siko_flyer
87. Kit
88. n7188u
89. gerryndennis
90. JNorton
91. misterv
92. Mustangman40
93. OntAeronut
94. proptop
95. scottrc
96. scirocco14
97. pt19 flyer
98. Doug47
99. b.bixel
100. bikerbc
101. weezle
102. Mtthwacrss
103. matadco
104. rickbrad
105. GaryHarris
106. Roary m
107. P47Tbolt
108. jp boud
109. arrdee
110. KaP2011
111. HFrank
112. custombuiltrc
113. jquid
114. dasquirrelisme
115. KC10Chief
116. Tommy D
117. Do328jet
118. sirzepp
119. mrshea
120. AJsToyz
121. svenska3
122. I FLY
123. turnscrew
124. SteveW
125. Super08
126. ma_mulcahy
127. digital_trucker
128. ARTP47
129. us020140
130. Profiled
131. kgibson4
132. r/coldie
133. Tubthumper
134. JH313
135. TWIN FLYER
136. Fliegerboy
137. Doug Robinson
138. thom25
139. Yak13
140. richwill11
141. what tree
142. Ranc68
143. Jimm
144. Calvinman
145. GeeBeer
146. dwreel
147. camss69
148. mattnew
149. alfredntucker
150. sdcranford
151. rctmpilot
152. winybakken
153. jpmorgan
154. Scully7272
155. balsatermite
156. Falkwulf
159. WontGrowUp
160. mpieklik
161. N410DC
156. Falkwulf
157. Larry J.
158. ochsnm00
159. WontGrowUp
160. mpieklik
161. N410DC
162. KLXMASTER14
163.
164. Lonestoner
165. Stankinator
166. Danster 1
Old 02-07-2018, 05:52 AM
  #3015
dasquirrelisme
My Feedback: (81)
I am picking up an Ultra Sport 40 kit this weekend but it is missing the plans. Does anybody have them on PDF so I can get them printed? If not maybe somebody has a nice set to sell me? Thanks for any help. The Ultra Sport was one of my best flying airplanes but I sold it and the buyer wrecked it inverted 3 foot off the ground. I think I am going to build another one.
Old 02-12-2018, 05:09 AM
  #3016
Danster_1
What do you guys thing of putting a Saito 180 in an ultra sport 1000 I just picked up both?
Should be about the same as the 40 size with a .61SF in it i'm guessing... ONLY BETTER :-)
USB #166 - Dan Mioduch, thanks for the number, I feel Ultra special now...
Old 02-12-2018, 08:21 AM
  #3017
jrf
My Feedback: (551)
Excellent choice. You will need to use a 3 blade prop for ground clearance, but those look and sound so cool, that will make it even better.
Jim
Old 02-12-2018, 09:24 AM
  #3018
Danster_1
I was hoping to get away with the 2 blade 16x10 and 2 blade aluminum spinner that was just delivered this past Saturday, dohh... I had to put a 10x10 on the .61SF for ground clearance with the 40 size. I was also planning in utilizing the 80" spitfire pneumatic landing gear I have and moving them out one wing bay as suggested in this thread. The spitfire gear are pretty long, not sure if they are going to fit yet or not but that is my current idea.
Dan - USB #166
Old 02-12-2018, 11:15 AM
  #3019
jrf
My Feedback: (551)
Lengthening the main gear has the effect of moving the wheels forward with respect to the CG and also increases the wing's angle attack when on the ground. You might get away with it if you fly from grass, but for any hard surface, whatever amount you lengthen the mains, you will have to lengthen the tailwheel height by the same amount, otherwise three point landings will be impossible and your ground handling will be squirrely.
Old 03-08-2018, 05:13 PM
  #3020
cmy6
Just got done framing up an Ultra Sport 60. Ready for covering. I’ll take #167 if I could please?
Old 04-07-2018, 04:29 AM
  #3021
KaP2011
My Feedback: (17)
KaP2011's Avatar
Default US 1000 build thread
So I'm finally going to get a US 1000 kit today, been wanting one for some time now. It seems like I remember reading a build thread where the builder modified the wing to a two piece wing, is it my imagination? I can't seem to find it anymore.
KaP2011
​​​​​​​Ultra Sport Brotherhood #110
Old 04-11-2018, 08:42 AM
  #3022
VincentJ
VincentJ's Avatar
KaP2011
I hope when you start your build KaP2011 that you will start a build thread! I would love to follow along. I have a kit as well (US1000) that I really should start. Finding these kits are getting very hard to find these days, and if you're lucky enough to find one, you have to be willing to part with some $$$!
Old 04-11-2018, 10:04 AM
  #3023
mmattockx
Originally Posted by VincentJ
Finding these kits are getting very hard to find these days, and if you're luck enough to find one to have to be willing to part with some $$$!
There is no need to find a kit. The plans for the US60 and US1000 are available online at Outerzone and Lazer Works will cut short kits for both at pretty reasonable prices.
Lazer Works: Lazer Works - Engraving & Design Radio Control Airplanes, Specialty, and More
Plans: https://outerzone.co.uk/search/resul...yword=feldmann
Mark
Old 04-11-2018, 10:52 AM
  #3024
paladin
My Feedback: (9)
the us1000 proto type was 72 in ws, the for production they added the two bays to make it 80 in ws. it made it fly totally different than the us 60; stall turns, barrel rolls, were much easier on the us60. but I had a sicker tiger in mine and when the engine would quite on take off I had to stretch the down wind pass because it just did not loose speed.
I sold mine, still have the us60 wore our one engine and replaced the second w electric, now its getting its second recover.
Joe
Old 04-11-2018, 10:58 AM
  #3025
Quikturn
My Feedback: (12)
Quikturn's Avatar
Default Us1000
Congrats on your US 1000 kit. If you start a build thread I’ll follow along as well.
A good friend of mine gave me an already built US 1000 airframe. The covering job is real ugly (all black with orange flames?) so I need to recover it and maybe put some retracts in it. It currently has fixed tricycle gear. I bought a Super Tigre S2500 and G2300 for it. I think they’re both similar in power but the S2500 is quite a bit heavier.
