*** Ultra Sport Brotherhood ***
#851
Banned
RE: *** Ultra Sport Brotherhood ***
Hi folks,
When I wrote in post 847 ___
"Results would only be for "show off"
I now realize that someone could interpret that as meaning to become "a hangar queen" or to be a non flying "display"
I was thiking, and still am, that it would be a real show to see the change in sweep angle while in flight.
Make a low speedlow pass into the wind with straight leading edge and the gears down and climb out to a 180 turn and come back on another low pass at high speed with the gears up and the wings swept fully back.
Lots of onlookers would ask "how did you do that ?" .
Zor
Zor
#852
It's been on my mind for awhile now, soI put a 13" prop on to see what kind of clearance I had.. With the 13" it's only two inches with the fuse level, I most likely will be using a 12" so that would give me 2.5".. Do you think I will be ok on a short grass field, provided a chipmunk doesn't stick his head up?
#853
Banned
Two inches prop clearance is plenty for a wheel landing.
On a three point landing the nose will be even higher.
I have only 1 1/2" on my Skybolt. 14 x 7 prop 3 blades on a Saito 125.
Zor
Zor
#854
Let me go and see if I can locate that issue so that I can elaborate more on the issue, I do remember some specifics as to how the author/builder of the Swing Wing aircraft overcame the mechanical forces needed to sweep, then bring back into regular configuration, I can see it in my head, but would find it kinda difficult to describe it in words, as to how it was set up.
And to answer your question, yes, I still do have many of the model airplane magazines that I had from 20+ years ago.. ( Ok, OK... Yes, Yes.. I am a bit of a hoarder, so sue me!)
Craig.
Craig.
#855
ORIGINAL: Zor
Zor
Zor
#856
I need some ideas.
Some of you may be aware of my (sort of) build thread, "Another Ultra Sport 60 Build Thread" here on RCU, and some of the (slow) work I've been doing to it. I've decided to use one servo for the aileron control as per the plans, however, I need to install the servo down into the wing at the center section, on its side. Not per the plans. I'm a little unsure as to how I should secure the servo in this space. I'm haveing a bit of a mental block. I'll be using flaps and the flap servo will be mounted aft of the aileron servo in a fashion identical to how the plans would have the aileron servo mounted, so just the aileron servo is taxing my brain.
#857
ORIGINAL: Tango Juliet
I need some ideas.
I need some ideas.
I didn't take pics of it, but my flap servo is off to the side of the center ribs (W1's) All i did was glued two rails 1/2" x 1/4" thick between W1 & W2 flush with the top of the ribs and spaced for my servo to fit. Then I sheeted over it, but didn't put any glue on the rails till after I cut the sheeting out for my servo.. I also ran my flaps into with in a 1/4" of the fuse, the fillet goes over the flap and looks nice and clean. It also gives me more flap surface and stops the flap from going up and further then it is supposed to.. I will take some pics tonight on how my flaps are set up, it might give you some ideas.......
Jimbo
#860
Nyrods. I'd post photos, but I'm at work and won't be home until late Tuesday night.
Let me see if this works... Here's an image from my build thread. It shows the two openings, the forward (larger) one is where the Aileron Servo needs to go. You can't see it in the image, but the Red, outer sheath for Nyrod is already installed in the wing and routed to the bottom of the wing about 2/3's out toward the tips.
http://www.rcuniverse.com/forum/fb.asp?m=10171916
#861
Here is how I set mine up. Where there servo is drawn on the sheeting, I installed two rails before sheeting it, I will cut it out once everything is all filled and sanded. I also ran my flaps in board to the fuse, about 3/8" away, had to make the suppliedcontrol rodsshorter but it wasnta big deal.. NowI have more flap surface and they come up againstthe fillets, it worked out pretty well..
#862
I don't need any ideas for the flap servo. I need ideas on mounting the Aileron Servo.
#863
I've already cut out the space where the W-1 was originally. I think what I'm going to do is lay the servo on it's side in the space so that the wheel (or arm in this case) moves right and left. If I have the geometry correct, I think I can get a bit of differential aileron from the movement.
#864
I looked at Mikes big thread and it looks like he brought his Nyrods up to just under the sheeting when they get to W1. http://www.rcuniverse.com/forum/m_68..._3/key_/tm.htmI didn't look further in the thread, but I would think he just dropped his servo deeper into the wing to make his connections..
#866
I found an old post Mike (Minnflyer) made withone of his beautiful renderings and he did just as I thought (much like you just said).
#870
Her she is, all ready to cover (well just a little more sanding to do on my fillets)!
This was a fun build and i could notbe happier how it came out, i will give her a nice covering job. The ST 90 fits very well andI can take it out without any problems.. I am glad I went with the flaps, kind of looks like a warbird from the back... I am having so much fun building again, I am going to start on my TF GS P47 right away. I was going to do it this fall, but I cant wait to dive on in..
A big thanks to everyone for putting up with all my questions and thank you to Minnflyer for his mods he posted in the big thread, I used several of them.
The covering will have to wait a week or so, have to pick back up onmy Little Toni so i have a plane for next weeks fun fly. I also have to balance the sons trainer so we can fly it tomorrow.
Here are some pics of her naked, now it's official, I am a member of the brotherhood.. If your wondering about the dash, I didn't do it because I am painting the canopy black.. Any recommendations on what paint to use?
#871
CO
I finally maidened my âHodgePodgeâ Ultra a couple of days ago. I also took it out today and got some good flights on it before my last landing. We have intersecting runways and I was coming in on the narrow one, but landed one foot short of the intersection. Nothing but rocks and gravel, so I bent one landing gear and broke the prop.
It is repairable with no problem. (as long as I didnât knock something lose on my gear mount)
I do want to report on the flying. Using Minnflyerâs advice I added flaps and retracts.
And my choice (because of price) I put a Super Tigre 90 on it. Once I figured out the low speed needle setting the engine is great. Starts with one or two flips and hasnât died on me in flight.
I have an older US 40 that I havenât flown in years, so I can't remember a lot about how it flew. But the first thing I noticed on my first flight of this one was just how solid these Ultra Sports really are. First take off was straight ahead, and the only bobble I have seen on it was when the wind was bouncing it.
I only used one or two clicks elevator and aileron to give it straight hands off flight.
I havenât added any weight or made any adjustments, just leaving the CG where it ended up, and it seems to be perfect. Even with the 90.
I may play with it more later to see if it makes it better in some maneuvers, but have no problem right now with ânormalâ flying.
I have never flown with flaps before, but it is a lot of fun. Slows down the plane and I donât have to do much, if any, changes to the pitch. I had worried that I may have too much travel in them. Full flaps are about 50 to 60Âș down. But it handles it fine.
Love the retracts. Even making a low pass at half throttle people remark how Fast it is. It is pretty fast, but just the looks of it going by with wheels up make it look 30% faster. After my hard landing and complaining about bending my gear, someone remarked how much trouble retracts are. I agree, However, on the Ultra, they are worth it. It would be almost blasphemy to build an Ultra without retracts.
I have another 60 kit in reserve, and I keep thinking maybe I should get a third. After the few flights I have made on this one, I canât see myself continuing in RC without an airworthy Ultra Sport in my hangar.
My only complaint- Look at the color of Monokote I used. In the air that and the sky are the same. Fortunately the bottom of the wing is black, so I can see it half the time.
#872
She's purdy ! I was hoping to get more done on mine this weekend, but I got called back in to work early, and it's probably the best flying weather we've seen in over two months [:@]. Oh well. Whatcha gonna do [&o]?
#873
Roy,
glad you like the combo with the ST90, that's what is on mine as well. Every time I read about a maiden flight of the US, it's always the same, awesome.. Now I really can't wait to get mine in the air, we finally have some good weather around here...
#874
CO
We just moved to Pueblo Colorado less than two years ago. This spring has been very very windy. The first half decent days we had I spent breaking in the ST90 (it didn't take very long by the way) We had a good windless morning last week and I got one flight on it. Today was the best day we have had in months. Very little wind all day long. Just sorry I missed the runway or I could have gotten a couple of more flights in.
About the Super Tigre. I had a hard time running it the first couple of tanks. It wouldn't idle, and transition from low to high was rough and the engine died.
The instructions said the low speed needle was preset so I left it for awhile. Finally I checked it out and it was out about 8 or 9 turns. I put it at around 4.5 and it idled perfectly, and smooth transition from idle to full throttle. It may turn out to be a good engine after all.
Also, TJ. I can't wait to see yours when you finish. I have been following you on your build thread. Me, I just slap them together and go fly, but you make it an art form. (that's why I don't show any close up pictures. lol)
#875
TX
All this talk about maiden flights, well I just started my US .60 tonight. Got the tail done and about 1/2 of the first wing half. Going to do the flaps and retracts on mine also. I actually made my first flaps down landing this morning with a contender. Can't wait to Get this one in the air!
