*** Ultra Sport Brotherhood ***
#1202
RE: *** Ultra Sport Brotherhood ***
Yep, I did all that. Washed completely, Hot water in the dye, left to soak for 24 hours even. I even tried the trick the next day of adding vinegar to the mix. I read that somewhere, too.
I guess I'll grab up another box of dye and have another go of it. I am a persistant fellow!
#1203
I had the same difficulty with my US60 and RIT dye. I always died my canopies but this one, although it did take some color, it wasn't close to what I could do in the past. Just left it longer and lived with what I got.
Chris
Chris
#1205
Try the liquid Rit. Use it straight, dye just the inside. I dye mine befor trimming off the flashing stuff .
Arrdee
USB #109
Arrdee
USB #109
#1207
My Feedback: (67)
CA
Too bad ST doesn't make a rear exhaust design; I still have some of the old X61's and they ran very well. Actually, 'X' reffered to the port design, not the direction of the exhaust although most of the X designs were rear.
#1209
MI
ORIGINAL: Red_Jeepster
Looks like those exhausts weigh a ton! What is the actual weight?
#1210
Just got off the phone with my LHS....I ordered a 40 and 60 size Ultra Sport. The 40 size will be my first kit[X(]
Should be able to start the holiday break putting my first kit together....should be fun!
#1211
Cool! The US is not the best first kit, (only due to the nose and wingtip carving) but it's far from the worst!
You can cut down on the wintip sanding by doing what I do: First, skip what they say about hollowing them out, it's not worth the trouble. Second, rather than sand them round, I just round the edges so the tips are flat on the outside (I think it looks better like that anyway)
Also, if you haven't been following along... A very good mod is to move the gear out by one rib bay. It makes for a wider stance and better ground handling.
Another good mod is to cut about 1/3 of the inboard ailerons and use them for flaps. (On the 60-size they have you cut about 4" off the OUTboard side of the ailerons and glue them to the Trailing Edge - If you go with flaps, skip that step and run the ailerons out to the wingtips like on the 40)
#1214
Hey Minn, Without having gone back thru the 48 other pages of this thread, I am looking for a quick opinion on the US40.
Does it still have room for my Dave Brown mech retracts?
Also, do you move them out 1 bay like on the 60?
I did all that to my US60, but never built a 40 yet.
Who is the better Foam wing supplier for the US60?
#1217
ORIGINAL: JNorton
Wouldn't it be nice if they (Great Planes) would let us know? They do show the Slo-Poke as back by popular demand.
And the Dazzler is back in stock by January!
John
John
However, IDID notice that Tower kept jacking up the price of the US 40 kit from $99 when they announced it was "coming soon" to $119 when it was in stock. Guess they had to make up for the "special" offer codes.
Where and what do you fly John? We're practically neighbors!
#1218
MI
ORIGINAL: MinnFlyer
Yes on both questions.
I don't know of anyplace to get a foam wing. I'm contemplating cutting my own for my next 60
Ken
#1220
ORIGINAL: Roary m
What's this moving the retract gear out 1 bay? Is that for tail dragger setups?
If you use retracts, it also allows for a slightly longer gear strut.
#1221
TX
Just saw that Tower has the 40 kits again - VERY cool!! I have an unbuilt 60 kit, thinking I probably need an unbuilt 40 kit! HOping to build the 60 over this upcoming spring/summer. Will be doing full out flaps and retracts and also electric conversion on it as well.
#1222
My Feedback: (67)
CA
Ah yes, clearing the prop. I never paid attention to that; When Mr Feldmann made his prototypes, one was a taildragger run by, I think, an Enya 90, and his commentary was on the speed of the ship.
#1223
THanks Minnflyer - I am still thinking of built up wing, but since Ken (Box Car) gave us the info on Eureka, I will check them out. Either way, I prefer fully sheeted wings.
If I do go with the foam wing, then I'll stick some build pics as I go along.
#1224
A question about joining the wing halves. Both the US 40 and the US 60 have all the dihedral in the bottom of the wing: the top of the wing is flat. So is there any reason to follow the kit directions to join the halves right-side-up with the tips blocked up? Why not just join them with the halves upside-down and flat on the board? (I'm building my first 60, with flaps and fully sheeted wings, as suggested by posts on this thread. )
