avistar steering wheel problem
PA
its not the servo i checked when i got this, it like the control rod is hitting the fuse. and stopping it so the horn on the wheel bends
<div>Great illustration of the workings Minnflyer. I have this plane also and fond that the way it was set up really did not work to well. So I modified it. First I drilled a new hole for the pushrod that lined up better then the one provided. Second I moved the steering arm forward slightly so that when if pulled in it just stops short of the firewall, just like the drawings shown above.</div><div></div><div>TB</div>
