Top Flight Spitfire Question
Hi Lads,
Just a question regarding the Top Flight Spitfire kit. I am up to the stage where I sheet the top section of the fuselage, it says to cut the sheet from the template on the plans. For the life of me I cannot find the Fuse sheet template on the plans. Can anyone point me in the right direction? I would be most grateful.
there isn't a template on the plans. it's actually a scaled down version in the back of the instruction booklet so not much use. here is how i did it..... http://www.rcuniverse.com/forum/m_14...itfire/tm.htm# .....look at the last post on the page.
Ah, well that helps me out alot. The way the booklet describes it it sounds like theyre supposed to be on the plan.
Thanks for the reply Tubig, much appreciated.
I have a top flight spitfire ,I joining the wing to the fuselage to put the plastic wing fillet on. there is a small plywood fillet . I can't figure out were the small shape fillet goes. It doesn't show it in the manual pic.or plan.
