 Royal P-38 Kit >
Royal P-38 Kit
Royal P-38 Kit
Old 07-01-2010 | 07:04 PM
Default Royal P-38 Kit
I have a very old Royal P-38 Lightning. The kit is in a different box, and the plans are yellowed and torn, but the kit is complete. It even has fiberglass cowls, because the former owner didn't care for all the solid balsa block cutting, shaping, and forming. I would like the Royal kit Cessna 337 Sky Master, Cessna 310, FW-190, A6M2 Zero, or F4U Corsair. I also want the Top Flite P-51 Mustang, or AT-6 Texan. If anyone reading this post wants an even trade up for my Royal P-38 for above said kits, please let me know. thank you. That is for any ONE of these kits...NOT all kits, I'm sorry if my wording sounded strange.
Old 07-02-2010 | 10:47 AM
Default RE: Royal P-38 Kit
I have plans for all the royal kits and if you post your email I can send you them.
Old 07-02-2010 | 05:41 PM
Thank You for your reply, I have recently purchased the plans from e bay for the Royal Cessna 337, I'm just hoping I can find front and rear cowls re-popped from fiberglass. I suppose I can cut them from block balsa, but finding the block balsa that usually comes in those kits may be a bear. Thanks
Old 07-05-2010 | 08:46 AM
you can laminate them with thinner pieces to get the thickness you need very easy and alot cheaper than buying large blocks
Old 08-18-2010 | 09:47 PM
Klaatu's Avatar
Hullo, is it Frank?
I could be talked into trading one of my Corsair kits, since I have a duplicate. The others you mention, I have some of them but no duplicates. I am not sure anyone could talk me out of any of my one-ofs, especially the ones you mention. They are highly sought after, are they not? I do have a weak spot for the the P38. A friend of my dad flew one in the big one. He was a super nice guy.
regards,
- Jan
Old 08-19-2010 | 01:13 PM
My Feedback: (-1)
Check with Fiberglass Specialties, they have a lot of the glass parts for the Royal kits.
Old 08-19-2010 | 08:15 PM
yeah thats where the cowls come from............im at a loss
Old 08-21-2010 | 01:40 AM
Klaatu's Avatar
Fiberglass Specialties does not list cowls for the Skymaster. I cannot recall that they ever did. I have not opened my kit box for ages, but I am pretty sure that the kit calls for building the cowls out of lots of balsa parts. They have parts for the Hostetler Skymaster, but it is *much* larger than the Marutaka kit. Hmm, they have cowls for the Aviomodelli Skymaster. Still larger though, with an 87" wingspan. I would have to see them in hand - the Pica or the Top Flite 182 cowls may be closer to correct. Have you tried sending them an email?
I cannot say when or even if I will get around to building my Skymaster. Seems that when I do it would be a good idea to make a mold for cowls, eh?
Old 08-21-2010 | 05:41 PM
I was never aware Pica or Top Flite built a 337 I suppose I could write to them
Old 08-21-2010 | 07:05 PM
Klaatu's Avatar
ORIGINAL: frankolin42
They made Cessna 182 kits that are close in scale size to the Marutaka Skymaster. I was just thinking out loud that one of the 182 cowls might work at least for the front.
Old 08-21-2010 | 09:18 PM
Maybe you could email me the exact balsa block dimensions in your 337 kit, I don't have a problem widdlin large chunks of balsa into 337 cowls. Whatta ya say Bob? Whatta ya say Bill?
Old 08-21-2010 | 09:43 PM
I have a TopFlite F4U-1A kit. .60 size. Interested in that one?
Larry
Old 08-22-2010 | 01:01 PM
no thanks
Old 10-09-2010 | 11:59 AM
My Feedback: (149)
Hi, have an old Royal P-38 kit & did notice the plans call for 2deg side thrust. Was wondering if this was to compensate for IC engines turning the same way? Have purchased electric motors & will be setting up for counter-rotation. Also have fbgl cowls from Bay seller U.S.Wing to help with weight. Any thoughts wether the side thrust will still be necessary? Any insight & advice appreciated, Many Thanx - MeB
Old 10-09-2010 | 02:02 PM
Hi!
Not necessary !!
Old 05-30-2012 | 09:57 AM
Does anyone have plans for the Royal P-38 and P-51 kits? Any help would be much appreciated! [email protected]
