 sig four star 60 >
sig four star 60
sig four star 60
Old 07-15-2010 | 07:47 AM
Default sig four star 60
Im building a four star 60 and i need to know what servos. To use in it Thanks for the help.
Old 07-15-2010 | 08:12 AM
MinnFlyer's Avatar
Default RE: sig four star 60
Any standard servos will work fine
Old 07-15-2010 | 08:14 AM
RCKen's Avatar
RCU Forum Manager/Admin
My Feedback: (9)
Standard servos are more than enough for this plane
Ken</p>
Old 07-15-2010 | 11:02 AM
What a great choice in planes You have made.  Add 1/2" to the rudder and it's even better.
john
Old 07-15-2010 | 02:43 PM
ArcticCatRider's Avatar
Whatever kind you get....just put them as far forward as possible as this plane requires about 6,000 lbs. of weight in the nose to get the balance.
Old 07-15-2010 | 03:17 PM
+1 on the larger rudder, plus replace the landing gear with Dubro - stock gear is crap.
I've flown mine so much, I just wore through one of the CA hinges...
Old 07-15-2010 | 10:32 PM
My Feedback: (-1)
I use most everything supplied in the kit, The plane sits down like a feather floating on a breeze, if you bend the LG you have really done something wrong. Last month I built one completely stock, most of the others I have cut out wing bays depending on how well the student can fly. I also add to the rudder if the student is really good and getting into a lot of stunt flying. I have added to the elevator also but it isn't really required. Even in stock form the plane can do stunts pretty well. I have been using the 4* 60 as a teaching aid to building for my students first kit. Very nice build and no surprises. Good choice!!
Old 07-16-2010 | 11:01 AM
My stock axle bent taxiing on a paved runway.
(The gear bent when I did something wrong!?!)
Anyway, the Dubro gear makes it fun to fly and quite durable. Couple weeks ago I got hit by an errand crosswind gust that kicked it from a nice smooth almost landing 12 inches off the deck to very short lived knife edge. Only damage was a broken prop.
Maybe Gray Beard can give me some tips on avoiding that crosswind issue?
As for the bigger rudder, it won't hold a knife edge well without it, and that slightly small rudder is the only issue. It tracks great, just falls off ever so slightly.
