Sig Kadet LT-25 build.
#102
RE: Sig Kadet LT-25 build.
An important note for anybody that will build this kit. I came out tail heavy. Before you install the tank floor, put in your RX pack and put it in as far forward as you can. So far I have to add a half oz. up front and sorta, semi glued the RX pack in and am still tail heavy. I may have to do some long screwdriver gouging to get the square pack out and figure out a way to fit a flat pack in there.
#103
Update. I had to tear out the tank floor to move the standard Footaba 600mAh RX pack up against the firewall and moved the receiver as far forward as I could and still had to add half an oz. of lead up front.
Maiden in the morning. [8D]
#105
