 Non-SIG Rascal 141 >
Non-SIG Rascal 141
Non-SIG Rascal 141
Old 08-08-2010 | 07:17 AM
Default Non-SIG Rascal 141
original SIG Rascal 110 was to little for me , and I start to build a 141 inch (3600mm) wing span "my own" RASCAL.
exactly, my plane only "looks like" RASCAL, because a construction is fully independent of SIG kit's.
it has a 2 spar wings, detachable 1550mm consoles and non-detachable 500mm middle-plane.
target was a 6-6.5 kg all-up weight at electric version, or 8-9 kg 50cc gas version.
here some pictures of building process (electric version):
http://forum.rcdesign.ru/blog_attach...3&d=1263939318
http://forum.rcdesign.ru/blog_attach...5&d=1271531039
http://forum.rcdesign.ru/blog_attach...7&d=1271528665
http://forum.rcdesign.ru/blog_attach...1&d=1272026029
http://forum.rcdesign.ru/blog_attach...8&d=1272029578
http://forum.rcdesign.ru/blog_attach...5&d=1272222227
http://forum.rcdesign.ru/blog_attach...8&d=1272631357
http://forum.rcdesign.ru/blog_attach...7&d=1273321645
http://forum.rcdesign.ru/blog_attach...4&d=1275327040
http://forum.rcdesign.ru/blog_attach...3&d=1279732412
http://forum.rcdesign.ru/blog_attach...5&d=1279910591
http://forum.rcdesign.ru/blog_attach...5&d=1281094941
http://forum.rcdesign.ru/blog_attach...6&d=1281207852
now I need just to complete a covering and install a motor and radio gear.
approximated all-up weight is 6.2kg
Old 08-08-2010 | 07:26 AM
R!aan's Avatar
Default RE: Non-SIG Rascal 141
WOW that looks good and not to mention it size
Old 08-08-2010 | 07:30 AM
I also have a "my own" 59" (1500mm) version for my son
http://forum.rcdesign.ru/blog_attach...3&d=1277233641
also need to cover-up
wood parts weight is 234 gr
Old 08-08-2010 | 03:21 PM
Acs_guitars's Avatar
Awesome Build! Did you user a laser cutter to make the "kit"?
Old 08-09-2010 | 12:04 AM
Yes, a local laser-cut service.
Old 08-09-2010 | 12:36 PM
I thought I saw burn around the edges... Makes kitting much nicer!
Old 08-13-2010 | 02:01 AM
here is a covered console
Old 08-13-2010 | 09:41 AM
That looks great. I love the rascal 110 and have always thought 12' version would be nice. Whats the power going to be, 30cc?
The best thing about my rascal is that I can thermal it up there with the buzzards.
Edwin
Old 08-13-2010 | 10:15 AM
looking great.... is that UC transparent Orange? This is my Rascal in UC Cream and Transparent Orange. Looks great in the sky.
Old 08-13-2010 | 10:22 AM
my power set-up is electric, 2.1 kilowatts or little more.
for 6 kilograms weight 1800 watts is enough. 30-50cc gas engine can be attached to, but gas version must be a little havier, for 1-1.5 kilograms.
covering is SOLARFILM Polyester Supershrink LITE orange and white.
Old 08-13-2010 | 11:37 AM
What size battery packs will you use?
Old 08-13-2010 | 01:59 PM
only "to try", I have a 4AH 7S1P pack, it can works about 4 minutes at full...
Old 08-19-2010 | 06:47 AM
http://forum.rcdesign.ru/blog_attach...6&d=1282161656
glued tail.
Old 09-12-2010 | 03:17 AM
only wind screen and radio not installed yet
http://forum.rcdesign.ru/attachment....0&d=1283972229
http://forum.rcdesign.ru/attachment....2&d=1283972267
http://forum.rcdesign.ru/attachment....3&d=1283972274
http://forum.rcdesign.ru/attachment....4&d=1283972281
Old 09-25-2010 | 09:29 AM
before- and after-test flight photos here
http://forum.rcdesign.ru/blogs/2452/...l#comment37658
it flies at half throttle and land very slow, nice steering and gliding.
power-to-weight ratio is 0.85, ready to flight weight is 7kg.
Old 09-28-2010 | 02:34 PM
here is first flight video
http://www.youtube.com/watch?v=yTq0DLnfwJU
