Where to buy pull-pull accessories ?
My Feedback: (46)
rajul:
The dubro set up may be ok for smaller planes but the sharp edges on the rigger couplings tend to cut the cable, you might want to look @ the pull pull set up @ www.swbmfg.com they use what looks like a nylon bullet, I made some myself out of a piece of nylon & a grinder, drill a hole in the flat side of the nylon bullet & thread a hanger 9 turnbuckle or a 4-40 X 1" control rod & swivel ball link or steel clevis, drill 1/16" hole through the side of the bullet about 3/8" from the pointed end. Thread some kevlar fishing line through the hole & crimp it or I have in the past just tied a bowlen knot & put a drop of ca. I hope this helps if you have access to these things you will have a much better set up than dubro can offer you. Check out SWB, it is really easy to make.
Gil
Gil
