Thrust line
Anyone tell me the thrust line of a Bridi Big Bee.
Measured from the bottom of the fire wall. Have plane, threw away the prints, changing motors from G62 to a Poulan 46 Thanks, BB1 |
RE: Thrust line
The thrust line question has been asked before. It is a line perpendicular to the propeller, through, and parallel to the center of the crankshaft.
Les |
RE: Thrust line
Hmm let me rephrase the question.
The fuselage thrust line. BB1 |
RE: Thrust line
1 Attachment(s)
Why do you need to know? Have you flown this before? Changing engines shouldn't make any difference. Just for info I fly mine with a Super Tigre 3000. No issues. Is the firewall square with the bottom of the fuse? Mount the engine with the crankshaft centered if possible. I find this to work for me. Hope the pics help if they show up.
RE: Thrust line
1 Attachment(s)
Yup, been flown on a G62. BIG and gentle.. As all of Joe''s planes are.
Major problem is it will not stop on a paved runway with the big motor and a 22x10 prop. This year, I'll be flying off of a paved runway. The motor mount on the Poulan 46 is a large mount and the mount on the G62 is the usual cup mount. I just need the measurement from the bottom of the firewall to the center line of the motor mount By the great looking plane! ;) I'll post some pics later when I get the motor mounted and the cowel built. Thanks a bunch, BB1 |
RE: Thrust line
My son flew one of those until he was flying inverted over our empty lot flying site, and he did an inside loop, with not quite enough clearance from the ground.
Les |
RE: Thrust line
ORIGINAL: LesUyeda My son flew one of those until he was flying inverted over our empty lot flying site, and he did an inside loop, with not quite enough clearance from the ground. Les OUCH. [>:] I don't care how good ya put em' together, when ya smack the ground, they go back to a kit. BB1 |
RE: Thrust line
1 Attachment(s)
Finally found out where the thrust line was, sooooooo in went the Poulan 46 converted by Terry at CH a loooong time ago.
Burrrrrrrrr, too cold to take outside and start...wife won't let me start it the "man cave." [>:] Booooooo!!!!! BB1 |
| All times are GMT -8. The time now is 03:46 PM. |
