RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   adding wing tubes? (https://www.rcuniverse.com/forum/kit-building-121/10494376-adding-wing-tubes.html)
rye 05-01-2011 05:16 AM
adding wing tubes?
hi guys
ok i am going to build a gp goldberg anniversery cub kit i would like to use a two peice or be able to remove the end panels of the wings and leave the center on the plane i think that the wing has a dieheil of 3/4 ? how would i cut the holes for the tube and what size do u think i should use ,thanks rye
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXYXF6
carrellh 05-01-2011 08:40 AM
RE: adding wing tubes?
I'd go with 3 wing sections due to the dihedral. The Bruce Tharpe Super Flyin King http://www.btemodels.com/sfk.html uses 3 sections. His joiners are metal bars rather than tubes. Check the pictures on the page, and possibly call him for ideas. When I was considering his Delta Vortex kit I called him with a few questions and he was very helpful.
bigal126 05-01-2011 04:24 PM
1 Attachment(s)
Funny you should ask. I just completed a Goldberg Sukhoi and added a wing tube. It came out great. I put in slight dihedral. My goal was to have the top of the wing perfectly flat, and all the taper of the wing on the bottom. To do that, when I cut the wing tube holes in the ribs, I maintained a constant distance from the top spar. It wasn't that difficult to do. The sukhoi has a similar wing span (72.5"). I purchased a 3/4" x 30" carbon tube from TNT, that worked perfectly. See the pics, they expain it better than I can.
rye 05-01-2011 05:26 PM
thanks i am going to try it ,rye
scale only 4 me 05-02-2011 04:29 AM
You really don't need a wing tube, a short joiner system and making the wing struts functional is all you need to do
rye 05-02-2011 07:18 AM
how would i make the struts functional ?
scale only 4 me 05-02-2011 10:20 AM
There are a number of ways I'm sure, do some research on the Balsa USA Cubs, or Hanger 9,, they have functional struts.
Basically you replace the lightweight wood with either Aluminum aero-stream tubing or shaped hardwood and engineer some bolt-on attach points.
take a look at the hanger9 Cub manual, starting around page 36
http://www.hangar-9.com/ProdInfo/Fil...nual-LoRes.pdf
good luck
