RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   Having trouble installing throttle servo, Help needed (https://www.rcuniverse.com/forum/kit-building-121/10611258-having-trouble-installing-throttle-servo-help-needed.html)
mally00 07-07-2011 08:23 PM
<span style="font-size: medium"><span style="font-family: Comic Sans MS">I have an extra 300s 60 size kit and i have installed the engine in the right position but the fuel tank is stopping me from running the throttle rod to my servo insinde the body.
pls i need help
</span></span>
huck1199 07-07-2011 09:00 PM
RE: Having trouble installing throttle servo, Help needed
Are you using cable or rod?
mally00 07-07-2011 09:10 PM
I am using rod. I don't think i can use cable because throttle does not have a spring.
Boomerang1 07-07-2011 11:15 PM
What you may have to do is run the throttle linkage against the fuselage side & angle the linkage across after the firewall.
99% of model engines don't have a spring return on the throttle. The cable Huck mentions has an inner cable & an outer sleeve & is quite stiff & will pull as well as push. I find cables, either wire type or plastic type (known as snakes or Gold N Rods), the easiest for throttle linkages. - John.
mally00 07-07-2011 11:54 PM
Could i turn the carbi around the other way so the throttle is on the other side of the engine and just missing the fuel tank.
biam 07-08-2011 02:45 AM
ORIGINAL: Boomerang1
Ditto, cables and Golden rod works just fine;)
MinnFlyer 07-08-2011 04:31 AM
1 Attachment(s)
Can you bend the rod?
ARUP 07-08-2011 07:15 AM
Can you tap a bolt hole into a fwd location of the motor mount to mount a crank that goes back to the throttle? Use ball links for connection.
R8893 07-08-2011 08:43 AM
mallyOO Yes you can turn the carb around, note that fast/slow direction will reverse
Chuck
