RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   replcement wing kit (https://www.rcuniverse.com/forum/kit-building-121/11487826-replcement-wing-kit.html)
earl267 04-22-2013 07:05 AM
replcement wing kit
I have a super sporter 60 and it crashed need new wing but can't find any makers, anyone no of a place where I can get the wing. Thanks
FlyerInOKC 04-22-2013 07:18 AM
RE: replcement wing kit
Any chance you still have the plans and one surviving rib? If so it would be easy to duplicate the wing.
FlyerInOKC 04-22-2013 07:29 AM
Here is a link to the building manual: http://manuals.hobbico.com/gpm/gpm-s...ter-manual.pdf
Trust me you'll want if you want to duplicate the wing! ;)
Here is a link to the parts list: http://www.greatplanes.com/parts/gpma0210pl.html
You could try calling Great Planes but the odds aren't good that they have spares but it doesn't cost anything to ask.
freddy s 04-22-2013 08:04 AM
1 Attachment(s)
I have everything you will need except the landing gear blocks.PM me if interested.
FlyerInOKC 04-22-2013 08:20 AM
Freddie, don't the ribs around the landing gear blocks require doublers?
freddy s 04-22-2013 09:11 AM
Yes you are absolutely correct on the doublers.I checked the manual and there are 1/16 ply doublers.that I do not have but look easy to make.I went to the landing gear on the fuselage.
KitBuilder 04-22-2013 04:52 PM
Wing is not repairable?.. would be faster.
TomCrump 04-23-2013 03:23 AM
I needed a wing kit for this model, too. Since I couldn't find one, I made a rib pattern from the plans, and cut my own ribs.
The rest of the wood is standard stock sizes, purchased from most hobby shops.
From there, it was any easy task to build a new wing.
turbo.gst 04-23-2013 04:00 AM
If you are open to a foam wing:
http://www.eurekaaircraft.com/foamwings/wing-s.htm
Edwin 04-23-2013 09:50 AM
Just a suggestion. I would move the landing gear to the fuse, just forward of the wing saddle. I use aluminum landing gear screwed in with nylon bolts. Break a bolt, replace it and fly again same day. I built a new wing for mine the same way Tom did. It failed the 'fly through the tree test'. Out poped a fuse with mostly wing stubs. That plane is still in flying shape. Just semi retired. I wore out 2 engines on that plane. Really great plane.
Edwin
