RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   G&L Hobbies Chipmunk Build (https://www.rcuniverse.com/forum/kit-building-121/11615757-g-l-hobbies-chipmunk-build.html)
jsanchez581 04-09-2015 03:02 PM
8 Attachment(s)
Hi,
I started to build the G&L Hobbies Chipmunk. A friend of mine recommended this kit to me and I got it in a heartbeat.
My plans are to fiberglass the wings, rudder, stab and elevators. I bought Robart ½" struts for the fixed landing gear. I also bought a DLE 55RA.
I started by making a template of the wing flaps and ailerons. I also added to the template the servos pockets, the landing gear cuts and the spars.
http://www.rcuniverse.com/forum/atta...mentid=2087585http://www.rcuniverse.com/forum/atta...mentid=2087586http://www.rcuniverse.com/forum/atta...mentid=2087587http://www.rcuniverse.com/forum/atta...mentid=2087588http://www.rcuniverse.com/forum/atta...mentid=2087589
I bought a block of aluminum on ebay to make the landing gear blocks.
http://www.rcuniverse.com/forum/atta...mentid=2087591http://www.rcuniverse.com/forum/atta...mentid=2087592http://www.rcuniverse.com/forum/atta...mentid=2087593
jsanchez581 04-09-2015 03:14 PM
12 Attachment(s)
Working on the wings
After I marked the wings with the templates, I cut the spars slots (¼ x ½" top and bottom) and the servo wires slot with a router. The holes were cut with a hot wire.
http://www.rcuniverse.com/forum/atta...mentid=2087595http://www.rcuniverse.com/forum/atta...mentid=2087596http://www.rcuniverse.com/forum/atta...mentid=2087597http://www.rcuniverse.com/forum/atta...mentid=2087598http://www.rcuniverse.com/forum/atta...mentid=2087599
I masked the cuts before gluing the spars, servos canal and landing gear ¼" plywood mountings because I am using Gorilla glue for this and I don't want to clean the mess when it expands.
http://www.rcuniverse.com/forum/atta...mentid=2087600http://www.rcuniverse.com/forum/atta...mentid=2087601http://www.rcuniverse.com/forum/atta...mentid=2087602http://www.rcuniverse.com/forum/atta...mentid=2087603http://www.rcuniverse.com/forum/atta...mentid=2087604http://www.rcuniverse.com/forum/atta...mentid=2087605http://www.rcuniverse.com/forum/atta...mentid=2087606
jsanchez581 04-09-2015 03:37 PM
14 Attachment(s)
Since I am not going to joint the two wings, I will use an aluminum tube that I ordered from Nick Ziroli. I had to make a jig to get a straight line when cutting the holes.
http://www.rcuniverse.com/forum/atta...mentid=2087607
I drilled the holes with the tube itself. I took into account the dihedral, so I put a piece of wood at the wing tip to elevate it 1 ½" (plans says 2 ⅛ but is too much for me) before cutting it. Then I aligned very carefully the tube and by hand I opened the wing holes.
http://www.rcuniverse.com/forum/atta...mentid=2087608http://www.rcuniverse.com/forum/atta...mentid=2087609http://www.rcuniverse.com/forum/atta...mentid=2087610http://www.rcuniverse.com/forum/atta...mentid=2087611
After that, I mounted the landing gear supports (red oak) and installed blind nuts. I also drilled ¼" hole in those wood blocks al the way through the plywood and into the foam and inserted ¼" wood dwell with gorilla glue. I was looking to have some extra support to this blocks. I don't want my landing gears to fail.
http://www.rcuniverse.com/forum/atta...mentid=2087614http://www.rcuniverse.com/forum/atta...mentid=2087615http://www.rcuniverse.com/forum/atta...mentid=2087616http://www.rcuniverse.com/forum/atta...mentid=2087617
Since I will cover all the holes, with 1/16" balsa to avoid the gorilla glue going into them, I am concern with the top part of the landing gear holes, since we use that area of the wing when handling it. I am running a test with carbon fiber cloth in a piece of foam that I am planning to glue in the top part (for the bottom part I will make it with fiber glass or carbon fiber) to see how it looks once it dries and I apply a 1/16" piece of balsa. Not sure if the CF will raise the balsa in the wing that you will notice when I glue the sheeting.
http://www.rcuniverse.com/forum/atta...mentid=2087618http://www.rcuniverse.com/forum/atta...mentid=2087619http://www.rcuniverse.com/forum/atta...mentid=2087620
In the mean time, I glued the stab with 30 min epoxy. I had to install "shims" in one of the half since they were not level.
http://www.rcuniverse.com/forum/atta...mentid=2087621http://www.rcuniverse.com/forum/atta...mentid=2087622
TonyBuilder 04-10-2015 07:38 AM
1 Attachment(s)
Good to see another G&L being built. I have built two of them, looks like your on your way, like the wing tube.
Here is a link to my last build
http://www.rcuniverse.com/forum/kit-...ary-build.html
http://www.rcuniverse.com/forum/atta...mentid=2087788
Will be falowing.
TB
jsanchez581 04-11-2015 03:31 AM
Thank you Tony... you did an outstanding job with your bird. Please fell free to give me any tips.
TonyBuilder 04-11-2015 05:41 AM
Thanks, what are you using to sheet the wings, stab and rudder, glue and balsa thickness?
I also would recommend a paper tube for wires if you haven't already done this. The DLE55 is perfect for this and when I build my third as a super chipmunk I may squeeze a 61 in it. I would pin the side ply on your gear bays with dowels into the foam, otherwise your doing good.
TB
jsanchez581 04-17-2015 05:29 AM
Thank you TB, your Chipmunk job was just impressive, and I will "borrow" with your permission some of your ideas.:rolleyes:
My progress this week have been slow due to some commitments, but here we go.
I did put some dowels into the ply on the side and into the foam. I think I went around an inch into the foam... do you think that I should go more?
jsanchez581 04-17-2015 05:41 AM
TB, I am using 1/16 x 4" balsa for the sheeting and gorilla glue on everything. I sanded very smooth on the bench and then I applied the gorilla glue on the rudder and the stab. I haven't sheeted the wings yet, but I am planning to do it this weekend, so please I will appreciate your opinion on how deeps do you think the dowels should go into the wing, because this is the perfect time to do it before I sheet the wings.
jsanchez581 04-17-2015 05:53 AM
3 Attachment(s)
Progress on the wing.
I installed the tube, sanded the dihedral, cut the rib # 1, opened the wings tube, added an alignment dowel and the glued the ribs using the tube as a guide.
http://www.rcuniverse.com/forum/atta...mentid=2089805http://www.rcuniverse.com/forum/atta...mentid=2089806http://www.rcuniverse.com/forum/atta...mentid=2089807
I did a mistake with the photos... I saved from my camera SD into the computer as the original file, and now those are too big. I had to create a copy of a few of them with a lower resolution to upload those to this site.... lesson learned...
jsanchez581 04-17-2015 06:14 AM
8 Attachment(s)
STAB
I sheeted the stab with 1/16" balsa and gorilla glue activated with water (applied water in spray).
I like a very thin trailing edge on my control surfaces (1/32"), but you cannot do that with balsa because you'll ruin it just on transportation. So I use G10. I make a "g10 sandwich" with 1/32" g10 an ⅛" of balsa. I cut an strip of ⅜" of g10 to make the
sandwich. I use carpenter glue for this.
Then I cut the trailing edge (around ⅜") -the elevators in this case- and glue the g10 sandwich. The next day I sand the sandwich until I get to the g10. With this you can get a very thin trailing edge and not a fatty one like ⅛" or ¼".
Now you can hit the trailing edge with pliers and you will not damage it.... Just a preference.
http://www.rcuniverse.com/forum/atta...mentid=2089808http://www.rcuniverse.com/forum/atta...mentid=2089809http://www.rcuniverse.com/forum/atta...mentid=2089810http://www.rcuniverse.com/forum/atta...mentid=2089811http://www.rcuniverse.com/forum/atta...mentid=2089812http://www.rcuniverse.com/forum/atta...mentid=2089813http://www.rcuniverse.com/forum/atta...mentid=2089814http://www.rcuniverse.com/forum/atta...mentid=2089815
TonyBuilder 04-17-2015 12:43 PM
the deeper the better as the foam will absorb the stress if they are longer. I used carbon fiber dowels. But your install looks good and should be ok. When I crashed mine the wings broke right after the gear, you can only make it so strong till something has to give.
1/16 sheeting should be ok, I like to use 3/32 as I like to sand and don't want to burn threw and end up with 1/16" anyways. If you pre sand you should be good.
TB
TonyBuilder 04-17-2015 12:47 PM
Originally Posted by jsanchez581 (Post 12023937)
STAB
Very nice, yes you can use any of my methods and ideas as I will be using your G-10 TE, modified though :cool:
TB
TonyBuilder 03-18-2016 09:22 AM
Resurrecting my chippy, I gave it to a friend and he started stripping it, but now he is giving it back to me so I can redo it and have a new chippy to fly. I will glass the wing and paint it white with similar starburst, and put a DLER 55 in it.
I will redo the flap hinges and the ailerons, but otherwise not going to change anything els...for now!
TB
