Smith Miniplane Winter Project
I am planning a Smith Miniplane for my winter project. I have not started building the kit. This will be my fifth kit. I plan to use a four stroke. I have a Saito 72 that I could use on this plane. However, I am considering a Magnum 61 or OS 52. What do you think about powering this plane? Is anyone else building a mini this winter????
RE: Smith Miniplane Winter Project
Hi mnrcaerobat,
I built one a couple years ago... I did a breif construction article... see it at: http://www.renderwurx.com/rc/SmithMini/index.htm I used the .46FX and it flew quite nicely... I think you are on target with a Saito .72... The Magnum .61 would fly it oto, but I think the O.S. .52 would leave you wanting. Nice little plane... I still have the plans... and often thought I'd blow them up 100% and make a 50% scale one... :) |
Nice review. I noticed you mentioned the cabanes. The plan calls for 0 degree incidence between the wings. The person I bought it from mentioned 0 degrees on the upper wing and the lower wing should be slightly positive 1 or 2 degrees to fly well. Another person mentioned the same thing in another forum from a Harry Higley Bipe book. How was yours done? Do you still fly the little bipe?
It was my first real kit build... I had a blast and it turned out nice. IT flew quite well, but it had a tendency to balloon under power...
I tried increasing/decreasing the upper wing incidence a degree or two without success... Not sure what doing the bottom would do... I do notice however that the stab is 0 degree as well... many of the more aerobatic bipes flew with a 1-2 degree positive incidence and this may very well fix the ballooning, but you're kind of committed either way you proceed... I sold it a few months ago to make room in the hangar... |
Well I've had six of these little bypes and talk about a ball that is an understatment.On my laast two I had TT40s on then and they just flew just fine for me. On all the plaanes I had everything at 0 degrees and never r3ealy ballooned on me. Did loose upper wing on one and it didn't matter how much up I gave it it still came down.:( But it stil is a very fun plane to have and do it up any way you want it show us your covering talents.:) I do plan on getting one of these little butes back up in the air cause you don't have to disassemble them to transport it.
Don't second-guess the plans. I've built two and am working on my third. 0-0 is the correct incidence for the Miniplane. If you have a ballooning problem and the wings are at 0 then it's most likely the engine thrust line that's off. These are great little planes. With a .60 it will be a lot of fun, but use throttle management.
You have built 3 of the most unique Smith Mini's out there being the only ones I have ever heard of that don't ballon on power... The plans call for zero engine thrust angle... basic design principle says there's gonna be some issues with that... but I also tried combinations of right and down...
I have spoken to several people about the Smith Mini... all with the same balooning problem. In fact I spoke to SIG and they told me themselves it was an inherent design personality. bottom line is it isn't a big deal... in fact a mix could be setup to gradually add a little down elevator as the throttle increases... It's no problem to fly with as is anyway, just alittle more difficult to hold a nice level line in a high speed pass... See below SIG's answer to an inquiry about this very "feature"... _____________________________ Hello David, The "ballooning" you refer to is normal for this, and every other, biplane I have flown. Biplanes, especially when they have a semi-symetrical or flat bottom airfoil are very speed sensitive, just like an R/C trainer. The faster you go, the more it wants to climb. And you have a pretty powerful engine in the OS 46FX. Much more than the old Enya 45 that was in the original. You can try some downthrust, but my experience is that it takes a LOT to even be noticable. My advice is to simply trim it out with a little down elevator and go fly. I haven't flown a Smith Miniplane in a lot of years, but I distinctly remember that it really performed nice snap rolls. Sincerely, Mike Gretz SIG Mfg. Co. ____________________________ ORIGINAL: CafeenMan Don't second-guess the plans. I've built two and am working on my third. 0-0 is the correct incidence for the Miniplane. If you have a ballooning problem and the wings are at 0 then it's most likely the engine thrust line that's off. These are great little planes. With a .60 it will be a lot of fun, but use throttle management. |
hmm.... maybe we are defining "ballooning" differently. I consider ballooning to be a sudden jump upwards under power. My miniplanes did climb under power, but that trimmed out with thrust adjustments.
Looks like we are defining it differently...
Looking at plans from Dave Patrick, Miles Reed, Bob Godfrey and others, they all have positive incidence in the stab... and usually 0 in the wings... the right thrust suggested varies, but the down is usually 0 too... At any rate... built as is, it's a fine plane... but it will most likely balloon under power... ORIGINAL: CafeenMan hmm.... maybe we are defining "ballooning" differently. I consider ballooning to be a sudden jump upwards under power. My miniplanes did climb under power, but that trimmed out with thrust adjustments. |
I think that I will build it to spec at 0 incidence all around. It sounds like per sig that the ballooning may be coming from the high performance 46 two stroke combined with the flat bottom wing. I found a Magnum 52 four stroke for $129 and I think I will buy it and use it for my engine. I just don't think that I need to overpower this little plane. CafeenMan, what have you used for motors in your previous two Smith's? What type of flying do you like?
mnrcaerobat - My first was powered by a Fox .45 BB Schneurle (70's vintage). It was good power for the model and it balanced well. I sold it to a guy who put a .60 in it and hot-dogged it all over and eventually into a tree. That model was silked and doped and believe me I cried when he did that.
The next one I can't recall what was in it. My current model has a Fox .61 Eagle III. I don't know if I'll keep that engine in it though. It was brand new when I stuck it in the ground about 15 years ago and haven't run it since. I replaced the needle valve and put it on the stand. Seemed ok, but who knows. I think a perfect engine for the mini would be the O.S. .52 or .72 4S. I think it will like the larger prop better than a high-rev 2S. Personally I like to fly large, smooth maneuvers. I'm not a throw it all over the sky kind of pilot. But my flying style shouldn't be taken into consideration because I'm not much of a pilot. I'm a way better builder than I'll ever be a pilot. Best of luck with yours. BTW.... it's a "flat bottom" wing, but the flat part isn't horizontal to the thrust line. That would actually be positive incidence. Make sure you measure to the center of the LE and TE to get it at 0. |
I powered my Smith with a RCV 60 4 stroke. Flys great. I put a servo in the tail the elevator. I put a servo to the rear of the cockpit for rudder pull-pull. I used Harry's book for construction/alignment tips.
I also put servos in the wings for the ailerons. Other modifications included a carbon fiber landing gear. I used JR DS368 servos in order to offset the increase in engine weight. It is covered in solartex. Enjoy the build. |
do you have any pictures?
I Built a Smith Mini acouple a years ago, my first kit build. Followed plans exactly. When I took it out it's first year the torque roll to the left got me a couple of times and ended up having to rebuild the lower wing. NOW, I put 2 degrees of right thrust into the motor and with the OS 52 Surpass she takes off nice and level. It does baloon some on throttling up but I can live with that . Just a real pleasure to fly and is cute as hell.
Norm,
Do you find any other flying characteristics with the 2 degrees on the engine? Did it make the plane any slower? Does it still fly straight? |
I had a enya 40 in mine and it was one of my favorite planes. Good Luck.
Jay Manion |
mnrcaerobat ,
The smith mini is my favorite "quick run to the field and fly" airplane. I can fit it in the back seat of my 4 door sedan without any disassembly and nobody ever recognizes it as the smith mini. Don't see many of the mini's around anymore. It's and older kit. Yes, It definatley gains altitude during full throttle. Can't do anything but trim it down. I run the new Saito 56 in it and flies perfectly, but is not over powered. I think the old OS fs 61 (4 strk) would be ideal. A 72 4 stroke would be over kill. Nothing like a serious flying plane.....no set up time, assembly or losing wing bolts. Just take it out, fuel it up and flyit! Jeff |
Smith mini was the first plane I built as a teenager, and can remember how I had to go home and build a trainer to learn how to fly. But once I was a better pilot and flew the miniplane quite a bit, I remember how the snap rolls were very impressive. It was a difficult plane to get on the ground at low power. It just kept wanting to fly.
Had a SuperTigre.40 in it, and flew it very well. I think your choice of a slighty larger four stroke will really give that little plane what it needs, as the one I built came out very tail heavy. Patriot P.S. Wish I stil had mine, but Dad sold it when I moved out years ago. Bummer.[:o] |
ORIGINAL: Patriot P.S. Wish I stil had mine, but Dad sold it when I moved out years ago. Bummer.[:o] |
I built a Mini and have a Magnum 62 FS which is more than adequate power for this airplane. It is fun to fly and is really good looking. I strongly urge you to read Harry Higley's Bipes book before building, and that you modify the inter wing struts, which he specifically tells you how to do. I built mine according to the plans and the struts were a constant source of aggravation and bother (this may be and indication of my building skills), so I tore the wings open and rebuilt them as he reccommends. No more aggravation.
Cafeenman, I wish I could have taken it, but no room when I went out to sea.[:o]
Maudib, that is a great idea. if you ever do blow up your plans, let me know. I would love to build an 88"ws Smith DSA-1. That would be beyond awesome, and very rare. I bet it would even fly much better than the original since it is much larger. Now you really got me thinking. hmmm..... How about a 45%, or even 50%? AW heck, lets just build a full scale that you can fly remotely or pilot? YEAH BABY!!!!!!!! :D Patriot |
In my humble opinion, this is the best kit ever produced. You want to talk about fun!!! I powered mine with a saito .56. Definately not underpowered, and that was at an altitude of over 5,000 feet in Denver! The Saito.72 'ought to be rip roarin' fun!!!
I never ran into the ballooning problem- Everything was set at o%; the engine, wings, and elevator. In a knife edge it would pull towards the cockpit, so I added 1% of negative incidence in the top wing. It seemed to correct the problem without changing elevator trim much. C.G. came out perfect with no other weight needed for balance using the .56.[8D] This is a great plane!!!!!! |
I'm lookin at the smith mini too. Probly won't get it for a while, but the one question i have is are the wings removable. if they aren't it probly won't fit in the car.
Bretthan man you musst have a really small car for this little bype not to fit in or even the trunk. Is your car RC also LOL.;) If your car is about average size you shouldn't have any problem halling it in the back seat or even the trunk. This plane is very portable and shoouldn't haave to be broken down. But if you have to yes it can be taken appart. But be careful of the upper wing cabaines cause they can move if not attatched to the wing.[:@]
nchrome,
I sent you a PM. Patriot |
nchrome,
Sent you another PM.:D Patriot |
RE: <span class=
Hi Guy's,
After reading this site the last few day's : :D I ordered the plan's from Sig to scratch build a Smith! YEAH I am so excited. I've been at this hobby 1 year and this would be my 4th plane. My 2nd plane died a slow (spiralling) death after 6mo flying ( 4star 40), My current plane is a Big Stick 60 (great plane) ?? Do you think it would be a good idea to tame the smith down a bit by expanding the wing span a little ( 4 to 6 inches ) OR build as is? 2nd ? I currently have a OS LA46 for this plane or would a Saito 56 be a better choice? [8D] Thanks!! |
RE: <span class=
I just bought my kit!!! thanks for teh 'inspiration guys!! :D
Now, waiting for it to arrive (mail order) and am still wondering what to tell the wife!!! :D:D:D "It's a Christmas gift to myself!!" yeah, that should work! |
RE: <span class=
ORIGINAL: dr_wogz I just bought my kit!!! thanks for teh 'inspiration guys!! :D Now, waiting for it to arrive (mail order) and am still wondering what to tell the wife!!! :D:D:D "It's a Christmas gift to myself!!" yeah, that should work! |
RE: <span class=
Haha will do...
I guess, as long as I spend more than the $100 i spent on myself on her, it'll be OK. Now, she did want two new Play Station II games.... :D:D |
RE: <span class=
Wildman3 build according to the plans. If you want to tame it down use the throttle and the low throws of your radio.;) Expanding the wings would only make it hard to land cause I have a Sig ST Ryan and I converted it to a bype and I should of reduesed the upper and lower wing span. Cause for a plane like this you shouldn't be able to catch thermols but guess what I can with it. [8D] Took me about 15 mins to land this baby without damaging it just wouldn't stop flying. And I didn't want to put it in the tall grass and maybe damage something.That is one of my winter projects to reduse the wing span of her. Cause she realy looks good as a bype.[&:]
RE: <span class=
1 Attachment(s)
This is a bit off the subject of the Sig SMP, but I can't help but pipe in. Back in the early 80's a friend of mine and I designed and drew up a set of plans for a 1/4 scale SMP. I have now taken those plans and doubled them and now have a 1/2 scale version under construction. A local fab shop bent up a set of landing gear for me and I also have a cowling plug under construction to make a fiberglass cowl. I ran across a deal on a new 3W-150. Probably way too much power, but what the heck, it will fit inside the cowling. Hopefully will have it complete and ready for competition next year.
RE: <span class=
1 Attachment(s)
I powered my miniplane with a magnum 46.
An old freeflight trick to stop the ballooning is to set the stab at 1 degree positive to the datum line. This will give automatic increased down as speed increases. It also helps with inverted flight. |
RE: <span class=
:D Okay, I'll quite being a chicken and make it the acrobat it is : ? do you think the saito 56 is a good choice?:eek:
RE: <span class=
MR.Scale...any chance of getting a copy of your 1/2 scale plans?????????
RE: <span class=
It is for general flying. It won't pull it unlimited veticle, and it probably won't hold a hover, but at 5,280 ft in Denver, mine came pretty darn close. It had all the muscle you need in reserve. It is a strong combination, and I didn't need to add lead anywhere to balance it out. Plenty of power for any manuver that doesn't maintain a hover.
I would suggest that if you are looking for the verticle performance to use the Saito .72. It is lighter and stronger than it's brother, the .65, and the mounting specs I believe are Identicle to the .56. You'll probably have to add lead to the tail to balance it out, however. But there is PLENTY of wing area for the weight, and I believe the ariframe is strong enough for it. As aerobatic as it is, keep in mind it is not the ultimate, and will not throw the manuvers as easily. (But it is still fun as snot!![8D]) |
RE: <span class=
1 Attachment(s)
Flythe9 is right with regard to positive incidence in the stab. As you can see in the picture, my plans call for +1 degree.
SBD3, let me think about it. It is a big task for me to make these plans. Where is Flatrock in relation to Seymour? |
RE: <span class=
Mr. Scale I am about 12-15 miles north of columbus......
RE: <span class=
1 Attachment(s)
I loved my Miniplane, it seems to be one of the "most loved" kits around! Mine was powered by a Magnum .52 2stroke and at 6300 feet had plenty of vertical power for traditional aerobatics. Very gentle stall and good low-speed handling. Flew "like a bigger plane", real solid and steady feeling. A good windy-day model. Lightning snaps, beautiful spins and inverted performance, knife-edge required elevator and aileron correction. Weight came in at 5 1/2 lb. I loved flying from the snow with the Smith on skis, and am sure I'll have another some time. (On my 2nd Hog-Bipe now.)
The Sig model is one of their "craftsman's kits" meaning the structure follows the full-scale as much as is reasonable, so it's an involved build with stick-built fuselage sides. It would be quite an eye-opener to somebody who's cut his teeth on liteply tab-in-slot construction. The result is a light, strong, realistic model the builder will be proud of. Mine had servos in the lower wings at the ailerons, hidden on hatch plates. The engine and muffler were fully enclosed, looked really great. No trouble with the ABS cowl. SIG ABS parts can be covered with Ultracote. Monokote was brutally difficult to use for the boxtop trim scheme, Ultracote next time. I built the interplane struts using K&S airfoiled aluminum tubing. Epoxy joints. The ends were stuffed with wood, then the stock alignment pin and screw plate arrangement glued in. They turned out real nice, light and good-looking. Higley's Biplanes book features the Sig Miniplane and is well worth studying for alternative building techniques. Mine went together fine using the kit instructions. I thought the rear fuselage box felt quite flexible and like it would easily break glue joints. Diagonal 1/8 square bracing was added and completely stiffened the fuse with negligible weight gain. FWIW, my opinions: This is a pretty small, hot airplane and gets small quickly. For this reason, I did the sunburst trim scheme on the tops but left the bottom solid red. The contrast really helped keep the pilot "out in front of the airplane" and helped me feel confident enough to really wring it out. :D The Smith is a scale model of an aerobatic home-built aircraft with ailerons on the lower wing only. Although the airfoil allows decent inverted performance, it's not a symmetrical wing. The prototype was not powered for unlimited vertical or gigantic manuevers. As small as the Sig kit is, weight control is more important to good flight properties than stuffing in a bigger engine. A .46 2stroke will fit within the cowl, but a .52 4stroke would be awful nice. I don't see the point in overpowering this scale model, the Hog-Bipe is far more aerobatic with 4 ailerons and symmetric airfoil, and is LOTS easier to build. The Smith got a lot of admiring attention, flew so nice, and I miss it. The next one will get blown up to around 60-inch wingspan for a 1.20 4stroke, one of these winters... |
RE: <span class=
Swooper - What a neat backdrop. One of the nicest I've seen. [8D]
| All times are GMT -8. The time now is 10:32 PM. |
