RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   HELPPPPPPPPPP CG for a dragonlady stick built (https://www.rcuniverse.com/forum/kit-building-121/1695571-helpppppppppp-cg-dragonlady-stick-built.html)
psavagerc 04-06-2004 08:28 AM
I have Aquired a Dragon Lady that was a Stck built and have no Idea what the recomended surface throws were or what the CG measurment was. I did the Caculation but I would also like to see what the original kit had to say
Pat
roysing 07-06-2004 02:32 PM
RE: HELPPPPPPPPPP CG for a dragonlady stick built
Pat
If your Dragonlady is 60-90 size ( 66 " span) the setting are:
CG: 4 - 4,25" from leading edge, or 102 - 108 mm.
Aileron: 9 mm up and 7 mm down.
Elevator: 13 mm each way.
Rudder: 40 mm each way.
I am flying mine with a ASP 120four stroke and this is great.
Roy Persson
Sweden
