RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   Unbending my elevator.How? (https://www.rcuniverse.com/forum/kit-building-121/1970871-unbending-my-elevator-how.html)
brsseb 07-08-2004 05:58 AM
The elevator control surface on my GP PT40 got a nasty bend in it. When hinged (using Dubro hinge kit for proper alignment), it kinda wants to "snap" to one side easily, due to its nasty bend. Is there a way to un-bend it? Perhaps soke it in water or something? (dunno if water is good for the balsa). Or do you do this while covering? (perhaps by adding more heat to the oposite side of the bent to make it stretch strait..?)
The ailerons got some degree of bend in them too, so i guess bent surfaces are a common thing in most kits. Must be a way to fix this. Very irritating thing:(.
DavidAgar 07-08-2004 07:40 AM
RE: Unbending my elevator.How?
I am not sure how much bend you have, however you can remove some of it by spraying it with a solution of ammonia and water and then putting some weights on it, or you can use your covering to remove it. Good Luck, Dave
cstevenpeterson 07-08-2004 09:07 AM
I had the same problem with an Avistar - I just made a new elevator. It was the easiest route to take and took about 1/2 hour to complete.
Steve
brsseb 07-08-2004 11:18 AM
Ill try to fix the bend during covering. It that dont help, ill just get a new one. As you say, it shouldnt take long to cut and hinge a new one.
brsseb 07-08-2004 05:45 PM
I read something in a Great Planes kit manual somewhere that you can spray window cleaner on balsa to make them easier to bend. It was useful when bending the sheeting for wings or turtledeck (thin balsa sheets though). Think this is a good idea for my (slightly thicker) elevator?
bojangle 07-09-2004 08:48 PM
I know what you mean by the "snap". Soak the elevator in water a few minutes , then press between paper towels/weights for a day. It will straighten out fine.
Before starting any kit, I straighten all bent parts. But if the piece is warped in the flat plane, then best to call the factory, they will gladly send replacement part. Don't even try to hinge parts that don't "mate" properly.
Bob
brsseb 07-10-2004 05:20 AM
Thankz. Gonna soke it and pin it to the board, making sure its strait in all dimensions, with towels and weights. Dont bother getting new parts, since the factory is in the US and im in Norway. Gonna take forever to order new onces. But I think I can fix it.
