RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   Side Mounting Engine Question (https://www.rcuniverse.com/forum/kit-building-121/1973389-side-mounting-engine-question.html)
KingCobra 07-08-2004 09:28 PM
This winter I plan on trying to modify my 4*120 to side mount the engine and enclose it in a cowl. What are the principal concerns/considerations when performing such an operation? Any tips/advice would be appreciated! Carlton Campbell
DavidAgar 07-09-2004 08:17 AM
RE: Side Mounting Engine Question
Side mounting is basically the same as you have it mounted now. If you are going to use a pitts type muffler, you need to make holes in the cowl for exhaust exit. You might have to reconfigure your throttle pushrod and fuel tank lines. Depending on the type of motor mount that you are using you may just be able to remove it and turn it 90 degrees. If you are using the Sig mounts you will probally have to redrill the mounting holes. With a cowled engine, cooling is always the main concern. Good Luck, Dave
Connery 07-09-2004 09:01 AM
1 Attachment(s)
I mounted the engine in my 4*40 at about 45 degrees so the muffler would clear the side of the plane and then build the cowl around it. Here what it looks like.
Ed_Moorman 07-09-2004 02:02 PM
1 Attachment(s)
This may not be a problem, but if you are using the standard muffler, make sure it will clear the gear. The 4* probably has a nose long enough so this won't be a problem, but it never hurts to check.
I side/angle mounted a .91 in a 4*60 modified and cowled. Worked great. Turned out fast.
The muffler shown is a Performance Specialties Ultra Thrust tuned muffler.
leftnut 07-09-2004 02:45 PM
it also depends what engine you want to use.
a standard 2 stroke carb..simple
with a rear need ..depending on how the intake barb sits.
you might wanna rought the line a little differnent to minimize
the bends of the fuel line.
