4*40 engine mounting
Hello all,
I am building a 4*40 kit with a Rossi 40 engine, and I was wondering if I could mount the engine horizontally (rotated 90 degrees to the right)? The problem is, that in order to do that I have to lower the engine center line in about 1/2''-3/4''. Thank you in advance, ;) Ari |
RE: 4*40 engine mounting
I rotated mine about 45degrees so that the muffler would still clear the fuse and then built a cowl to cover it based off of Tom Pierce's website.
Thanks Connery, but my Rossi can't seem to get in, in 45 degrees - it's too wide [:o].
Please people, tell me if there are any problems with mounting the engine at 90 degrees? Thanks again, Ari [8D] |
| All times are GMT -8. The time now is 02:27 AM. |
