RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   APC compatible spinner (https://www.rcuniverse.com/forum/kit-building-121/199938-apc-compatible-spinner.html)
rajul 07-18-2002 12:54 PM
I could not fit my 2.5-inch Dubro plastic spinner on my 11x7 APC propeller and it was a real hassle to file the spinner ! :mad: Is there a plastic spinner in the market that can fit APC ? Thanks guys ! :)
PHILLCO 07-18-2002 01:03 PM
IF YOU DON'T MIND SPENDING THE MONEY TRUE TURN WILL CUT THERE SPINNERS TO FIT. BUT IT AIN'T CHEAP.
LSP972 07-18-2002 02:07 PM
A Dremel tool with sanding drum makes short work of enlarging the cut-outs to fit a larger prop.
You used a FILE? Jeez; no wonder you're aggravated. That would take forever.
BTW, I would stay with DuBro. Now that Goldberg stuff is difficult to come by, the DuBro is the best plastic spinner available IMO. Stay away from the SIG on a powerful four-stroke. SIG spinner faces are held only by the two screws; these won't take the torque of a powerful four stroke. The Dubro, like the Goldberg, has four stout pins in addition to the 6-32 bolts/locknuts. Plus, you don't need a hammer to install it or a pry bar to get the face off, like you do with the Goldberg.
My pal broke a SIG plastic spinner on a YS 63, and I broke one on a YS 91; just by advancing the throttle.
Steve
rajul 07-18-2002 02:17 PM
Steve, could you post a photo of what your cutout looks like after Dremel sanding ? I am not sure if the sanding drum can fit my 2.5 inch spinner cutout. Thx.............. :)
LSP972 07-18-2002 06:59 PM
1 Attachment(s)
Sure.
This a Dubro 2.5" spinner, cut to fit an APC 16x6. I had to remove a LOT of plastic. But if you're careful to enlarge the cut-outs equally on both sides, and only remove as much material as necessary, the structural integrrity of the spinner will not be affected.
I used a standard (15mm in diameter) Dremel sanding drum with coarse grit. You'll be there all day if you try to use the smaller one. They only come in two sizes, that I am aware of.
Steve
LSP972 07-18-2002 07:03 PM
1 Attachment(s)
Here's a shot of the other side of the cut...
Steve
rajul 07-18-2002 10:17 PM
beatifully done !
Steve, your mod looks great! Very nicely done ! Thanks a lot for the pics and instructions. They give me a clear idea what to do. I don't have a Dremel but I have a RTX with the same size sanding drum. I'll go ahead and use it but wish me luck as I have only one go at it (no spare spinner)................. :)
Geistware 07-18-2002 11:09 PM
I know you said plastic but Dave Brown Products will cut your Vortech spinner to fit an APC propeller
LSP972 07-19-2002 12:23 AM
Glad I could help, Rajul.
Steve
bigbri 07-19-2002 02:21 AM
Sig spinners have cutouts that fit APC props at reasonable prices.......check their website
Good luck
Brian
rajul 07-19-2002 02:39 AM
Bigbri, I heard of many horror stories of SIG spinner breaking up even during throttle up in this forum. Weak design based on two screws holding the nose and backplate whereas Dubro has four dowel pins and two bolt/lock nuts............ :)
bigbri 07-19-2002 10:18 AM
Hmmmmmmmm. Interesting, I was about to try them myself. Guess I will hold off for a while
Brian
jollyroger 07-19-2002 12:30 PM
Sig Spinners
I have flown my 4*60 with an MDS 68 a number of times and the Sig spinner is still in tact It maybe just a bad batch or they weren't tightened correctly. Anyway mine is still ok. I waill keep an eye out though. Thanks. Jollyroger
LSP972 07-19-2002 01:36 PM
<<...weren't tightened correctly...>>
Well, how does one one INcorrectly tighten a spinner? Either it's properly fitted and lined up, or it's not, yes?
The two incidents I have personal knowledge of involved four-stroke engines; which have greater torque than a two-stroke. Is that the difference? I dunno.
But a hobby shop owner told me he stopped carrying the product because some of his customers were complaining that they were breaking the spinner with their electric starter.
Now, I know the kind of guy this is; the one who pushes the button, lets the starter wind up, and then jams it against the spinner. And they wonder why they have that ugly gouge groove around the spinner.
Still, DuBro and Goldberg spinners stand up to this abuse, so the point is made. And the simple fact is that the SIG does not have the additional supporting pins.
You pays your money, and you makes your choice...
Steve
