RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   Laser Cutting (https://www.rcuniverse.com/forum/kit-building-121/2387726-laser-cutting.html)
plasticjoe 11-29-2004 10:03 PM
Laser Cutting
What kit mfgers are laser cutting their kits ? I have heard bad things about die cutting if the dies are not sharp. If there are some die cut manufacturers out there that are really reliable I'd love to hear about them as well.
taildragger01 11-29-2004 10:12 PM
RE: Laser Cutting
depends on what kind of kit you are looking for. Aeroplaneworks makes the finest kits around and they lazer cut. allso balsausa and yellow aricraft. A&A Industrys lazercut . So again It depends on what kit your in the market for.
JWN 11-30-2004 01:59 PM
RE: Laser Cutting
Also keep in mind that just because a kit is laser cut does not make it a great kit. If the kit cutter does not take the time to verify the parts fit of their programmed patterns, the fit can be just as bad as a poorly die-crunched kit. OTOH, I have built many of the older Pilot, MK, IM and Yoshioka kits which were all die-cut and the fit was simply amazing. Again, it all depends on the kit cutter and how much time and effort they put into making their kit a quality product.
John
Time Pilot 11-30-2004 02:41 PM
RE: Laser Cutting
I've only built 2 balsa kits so far, one laser cut from Great Planes and the Tower Trainer .40, all die cut. I don't know if I was lucky or not, but the pieces in the die cut kit were all crisply cut--no crunching at all. I prefer that to the charred edges of the laser cut kit.
