Retract installation advice
1 Attachment(s)
Hey,
I am in the process of installing mechanical retracts on a GP P51D kit. The retract wire needs to bent forward in order to allow the wheel to fit inside the leading edge. I am debating between two options, illustrated in the attached pics. Which approach will be the easiest to complete ? which will be the most durable ? Thanks in advance. |
RE: Retract installation advice
I would go with the second pic because it would be easier to get a more precise bend away from the spring... as far as durability I would think either would be fine.
| All times are GMT -8. The time now is 01:30 PM. |
