RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   How To Figure Wing Loading??? (https://www.rcuniverse.com/forum/kit-building-121/273496-how-figure-wing-loading.html)
AJF 2 09-17-2002 07:07 PM
I should know this--but I just can't figure it out. If a plane weighs 25 lbs(400oz) and has 1700 square inches of wing--what is the loading? :confused:
tdwise 09-17-2002 07:24 PM
Wing Loading
Convert the 1700sq/in to sq/ft by dividing 1700 by 144 (12" x 12" = 144sq/in). That should give you 11.80 sq/ft. Divide 11.80lbs. into 400oz. and your answer should be 33.89oz per sq/ft. Big plane, huh! :D
I think I'm correct on this but check me.
Ted
AJF 2 09-17-2002 07:28 PM
SORTA BIG---84" bipe--Thanks for the help. (overmyhead)
tdwise 09-17-2002 07:42 PM
Correction...
It should read: "Divide 11.80 sq/ft...", not "lbs". Sorry...that's what happens when the phone rings...:rolleyes:
Ted
