Cap 232 rebuild ???
1 Attachment(s)
I'm in the process of rebuilding my cap 232 after a crash this summer. The horizontal stab was damaged in the crash and needs replacing. I got the old one cut out but that's were my questions come in. As you can see in the pictures there is quite a bit of dried epoxy and wood left in the slot, and the top of the slot is a little out of shape.
Do I need to remove the fuselage above were the stab goes and replace it with a new section, or can I fill in the gaps with something? What would you recommend to fill in the gaps with? Do I need to remove the fin and replace it as well? How much of the old dry epoxy do I need to get out of the slot? |
Cap 232 rebuild ???
1 Attachment(s)
another view
| All times are GMT -8. The time now is 01:03 PM. |
