RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   SIG Four Star 60 modifications (https://www.rcuniverse.com/forum/kit-building-121/3144374-sig-four-star-60-modifications.html)
Paladin049 08-05-2005 09:32 PM
RE: SIG Four Star 60 modifications
I'd like to know how you did the tips. That second wing I may build would be nicer with them.
kerrydel 08-09-2005 05:19 PM
1 Attachment(s)
I used 3/8" thick x 3" wide balsa and cut out the shape shown below. I basically traced around a portion of one of the wing ribs that I didn't use, but I extended it so it would end at the tip of the aileron.
Kerry
Paladin049 08-09-2005 09:04 PM
Very cool...thank you much! I was wondering if there was a plywood core with balsa attached or straight balsa.
kerrydel 08-10-2005 04:22 PM
Nah, I didn't bother with plywood. The wing tips don't take much abuse. Hanger rash is about the worst.
Kerry
jtsails 08-13-2005 12:55 PM
1 Attachment(s)
Paladin049,
Here's a couple of pics of my 4 star 60 arf. I added a balsa cowl, mounted the engine horizontal with a pitts style muffler, used a sullivan tailwheel and some triangle stock to reinforce the tail. I like those wingtips that kerrydel built, hum, another mod in the works?
Paladin049 08-15-2005 07:57 AM
Nice bird, JT! I like the cowled nose.
I am going to get a fiberglass cowl from Fiberglass Specialties for mine. Yes, I know I said !QUOT!I'm going to build it stock,!QUOT! but I just can't resist the finished look a cowl gives...and since the cowl is made specifically for the Four Star 60, it shouldn't be too much of a much. A skilled local builder has offered to help, too, so I'm a bit braver now...but not a lot!
Love the wingtips, too. Once again it adds a finished look.
mr70ss 08-16-2005 12:08 AM
1 Attachment(s)
Here is mine with a full build balsa cowl..
Mr70SS
airroy 12-26-2005 07:18 PM
mr70ss,
Do you have any more pictures of this blk and blu 4 Star? Nice work. Especially the covering.
Regards,
Airroy
mr70ss 12-27-2005 12:36 AM
Yea i do actually.. I don't want to try and take over the thread...:eek: but here is a link to a thread i started that coverers the build process. http://www.rcuniverse.com/forum/m_25..._1/key_/tm.htm
Javlar 04-08-2006 07:02 PM
1 Attachment(s)
Its been some time since the last post in this forum, but I thought I'd include some pictures of my recently completed 4*60. Before I started building I looked at a lot of old posts getting ideas on how I wanted to modify my 4*. I haven't flown it yet, so I can't say how good she flys, but I'm proud of how it looks on the ground. No new/original mods were done, but I tried to do as much as possible to make it not look like the stock 4*. (cowl, clipped wing, wing tips, sheeted turtle deck, cockpit dash, flaps, and fuel tank hatch)
Kmot 04-08-2006 11:47 PM
It looks great Javlar!! [sm=thumbup.gif]
jertsy 05-27-2007 03:23 AM
Kerry if you are still flying. What size ailerons did you purchase from Sig? Jertsy
TransparentOrange 07-22-2007 03:46 PM
Hey,
I am looking at all the modifications that you guys are saying about the four star 60, or 120. I have a Four Star .40 ARF brand new in box, and I wanted to make more of a faster, sporter plane for my brother. What you recommend to do?
John
BobFE 07-23-2007 07:31 AM
I built a 4*60 with flaperons. I didn't need to do any mods to the airframe. The kit starts out with seperate servo bays for each aileron. The only thing I had to do was not use a Y-harness and connect one aileron servo to an AUX position on my reciever. The plane really flys great!
For landing I rarely use flaps because the plane just gets too slow for me. A little wind and the plane is off course for landing.
I use a OS .70 and that's plenty of power, the plane is a little slow though. Takeoff roll is about 10-15 feet without flaps, and with flaps it's about 4-5 feet. I have plenty of power for climbing and manuevers. I am at sea level, though, so if your at a higher altitude you might need the bigger engine.
I built mine stock (except for the flaperons). I have no complaints about the roll rate. I probably will extend the rudder in the future because it doesn't have as much affect on yaw as I would like.
kerrydel 11-08-2007 10:44 PM
1 Attachment(s)
I'm adding some more info to this post because I've recently received a couple of questions about my wing tips. I simply removed one wing bay and then added the tip on. It was 3/8" thick balsa, so I just glued it on. I figured that the Monokote would keep it all together.
Below is a could ideas on how you could use thinner stock and add some support/stiffeners.
Kerry
Pit-Viper 1 11-09-2007 12:59 AM
Has anyone tried this with no dihedral in the wing? A buddy did it too a PT40 trainer and it flies awesome, not like a trainer especially on landings. Does still float nice though. Was just wondering if it would give it a little more speed and aerobatic ability? I know it's not a 3D plane, just want to try to increase roll rates and that sort of stuff. Have already done the wing mods and I do beef everything up while building so i can push them harder than normal. I also use spruce stringers on the turtle deck before sheeting. The current one is right at 8lbs dry after the mods.
Shane
haile 1 01-09-2008 11:54 PM
my cousin that is 84, and has been building sence he was in dipers, made one 4 star 60 with a cavan top-wing, and then a 4 star coupe. I'm going to make a 4 star bi-plane out of mine.
Tee Bee 01-10-2008 12:56 PM
1 Attachment(s)
Here's mine. Clipped wings, enlarged rudder, sullivan pushrods and tailwheel, Magnum .91 4-stroke. Fun to build and fly.
haile 1 01-10-2008 10:58 PM
how do u loud up photos on here ?
kbear 01-11-2008 12:19 AM
If you don't use the quick reply at the bottom of the thread, but hit the reply icon, there is a way to load photos at the bottom of the page. Your other alternative is to use off site photo storage like putfile.com. They will usually give you code that you can cut and past into your reply. When I use putfile , I do have to modify the code slightly to get it to work here though.
haile 1 01-11-2008 04:24 PM
1 Attachment(s)
heres some 4 stars
kbear 01-12-2008 08:29 PM
I'm kind of fond of the open cockpit wind screen idea.
haile 1 01-13-2008 02:06 AM
your stick stick looks like a tango 40 that I have. I'm building a 60 4 star with a top wing and using a 40 size tiger 2 wing on the bottom for a bi plane, and going with a 4 stroke 70 os for power.
kbear 01-13-2008 03:15 AM
ORIGINAL: haile 1
It is my attempt to build a coro plane at a reasonable weight. It came in a 5lbs. I was also experimenting with a thinner airfoil.
haile 1 01-13-2008 09:51 AM
what is a coro plane ?
