RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   Lainer Ultimate Pitts. (https://www.rcuniverse.com/forum/kit-building-121/316504-lainer-ultimate-pitts.html)
onewinglow 10-15-2002 09:34 PM
1 Attachment(s)
Well after 6 months of building on this plane I finally finished it. The kit is a very good kit but not what i would concider a beginners kit. The plane has a Moki 1.35 swinging a APC 17-8 at 8650 rpms. The plane weighs in at 11.5 pounds and is covered in Ultra coat.
I spent quite a while searching on the internet for pic of this plane but only found one. The covering schem is copied after a full size Japanese pitts.
The plane flies very well no bad habits and has very little coupling in knife edge.
I'm flying this with a Futaba 8uaf
onewinglow 10-15-2002 09:36 PM
Side view
1 Attachment(s)
Here is a pic of the side of the pitts
onewinglow 10-15-2002 09:38 PM
Bottom view
1 Attachment(s)
This is the Ultra coat 2 inch red and white squares
tinman 10-15-2002 09:57 PM
ahh it looks great glow....i'll bet it moves along with the MOKI eh?
-Tinman-
LuvBipes 10-16-2002 03:04 AM
Great job, OneWing. I have this kit under the bench and will get to it someday. Great color scheme, by the way!
How did the plane balance with the MOKI?? Had to add any weight?? Also, are there any tips or mods you'd recommend?
onewinglow 10-16-2002 03:25 AM
Balanced perfect
The plane balanced perfect, The Moki is just right, has great vertical.
I replaced the bottom stringers with spruce ones and fiberglass taped the top wing joints. you can see more at
http://photos.yahoo.com/osfp40
click on MY PLANES then on Ult Pitts folder
Thanks for looking
Scott
