RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   Balsa USA enforcer (https://www.rcuniverse.com/forum/kit-building-121/357815-balsa-usa-enforcer.html)
Constrictor 11-10-2002 02:04 AM
Balsa USA enforcer
Has anyone built this plane? and comments on building and flying appretiated
boogerman 11-10-2002 03:29 AM
Balsa USA enforcer
I am finishing up a Force One, the Enforceres little brother. My kit went together very well, and was fun to build. The fuselage construction was old fashioned, but it turned out well. Only took me two weeks from start to covered. Will get my radio installed tomorrow. Hopefully fly on Friday. If the Enforcer kit is like mine,you will have fun building it. I have seen Enforcers fly before, and they are great flying planes. HTH
ram3500-RCU 11-10-2002 07:49 AM
Balsa USA enforcer
Had one some years ago. I lengthened the nose 4 in. and installed retracts in mine. One cool thing it did was FULL throttle landing approaches. Fly it in full bore and because of the pusher and 3/8 inch up on both elevons, when you chop the engine, it will mediately stand on its tail and almost stop, then just add a little power. The nose comes down and she greases in, all in about ten feet ,after going about 90 mph. Watch the spins though, it may not recover. My brother crashed one that way. You will love this plane. Had a .91 4-stroke in mine.
ram3500-RCU 11-10-2002 07:56 AM
Balsa USA enforcer
Forgot to mention that i also added duel rudders for extra maneuverability. With these i could do flat turns , hammerheads,etc. I servo-ed one with a tie rod to the other.
Constrictor 11-11-2002 12:42 AM
Balsa USA enforcer
Any issues with gas tank line feed being so long from front of tank back to engine?
engine sucks fuel ok? Also what kind of muffler since the engine is on backwards
Edgar Perez 11-11-2002 01:25 AM
ByroBlaster Enforcer
You can use it for ducted fan...
Check ByroBlaster Enforcer
ram3500-RCU 11-22-2002 09:32 PM
Balsa USA enforcer
I had a "perry" pump on my 4-stroke and the stock muffler facing forward with a 90 deg. elbow on the end.
ADSPATTERN 12-31-2002 02:58 AM
Balsa USA enforcer
Constrictor
This may be a little late, since your post was almost 2 months ago. But I just flew my enforcer today for the first time and it was awsome. From the table to the flight was easy. The wing builds flat upside down. The fuse construction is no problem. The hardist thing to do was to bend the sheeting over the fuse. The plans call for the alerons and the elevator to be connected with nylon push rods to the center of the wing front. I opted not to do this. I put servo's in the wing closer to the ale. & elev. for better control. ( I've never liked nyrods) On to the flight. On take off, the ground control is very good. But without rudder, on windy days it might be a handfull. Once off the ground it went straight up. I had it turn sharp then the heat was on. The thing acted like someone kicked it in the butt. It started hauling ass. Turns were very sharp, rolls was even better. The only thing that spooked me was, when I backed off the throttle. The thing shot straight up about 12 foot or so. That was freaky. As I came in for a landing the nose lifted up, the plane slowed to a crawl and it sat down like a dream. Landing slower than a walk. This is the best plane I've flown in a long while. Need I mention, all the other fliers wanting to see it fly ( big time attention getter ).
Cdallas2 01-01-2003 06:10 AM
Balsa USA enforcer
Just watch out though, I had a Force 1 years ago but had a deadstick first flight. Well like most delta's without power they tend to glide like a brick. Would of made it with a flat thud but the newly built fence (finished earlier in the day) struck it's first victim. Sure looked neat and would love to build another.
ram3500-RCU 01-01-2003 07:41 AM
Balsa USA enforcer
Constrictor, Thanks for the thread. Got me thinking about an airplane that i had a ball with years ago until it died before its time in an inverted flat spin that it wouldn't recover from. The retracks i had installed changed its geometry. Before the gear change, it would do a full power ,inverted, flat spin that it would hover or slightly rise in and easily roll out of. With the lengthened nose, i found out this was not a good attitude for it. Anyway, i ordered another Enforcer and am in the process of building it now. Had the fuse. framed up and skinned in one evening. After a week of " spare" time, the wing is about 2/3 done. I do use nyrod type push rod for this wing, but i get the carbon fiber core not the nylon and fill the bays that they run through as well as the leading edge bays with non-expanding foam after the bottom sheeting is in place and before the top is sheeted. Just let it harden, trim off the excess (I use a hack saw blade), block sand, and sheet as normal. No flex in your push rods and adds a lot of strength with very little weight. I have an OS91 2 stroke I think I'll put in this one, so i added some tri stock around the gear mounts for the additional weight. Can't wait for spring in Ohio. Thanks again!
Edgar Perez 01-02-2003 01:16 AM
Balsa USA enforcer
If you want to do something real nice with the Enforder, check these out:
http://www.rcuniverse.com/showthread...light=enforcer
http://www.pcisys.net/~mrmike/enfrcr.htm]
