RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   Adhering Cockpit Combing (https://www.rcuniverse.com/forum/kit-building-121/369703-adhering-cockpit-combing.html)
scott hayden 11-17-2002 05:17 PM
Hi Folks,
I have some sig cockpit coaming. What works best for adhering the combing to balsa?
Scott
rwh 11-17-2002 05:25 PM
I use rubber glue. Roll it on the edge of the balsa with a Q tip, leaving just a trace of glue on the wood.
Usually the coaming forms a complete circuit around the cockpit and tends to expand outward and thus stay in place, even without glue.
scott hayden 11-17-2002 07:00 PM
thanks rwh
Gbee 11-17-2002 09:16 PM
I use thin CA glue with a fine tip on the bottle. Put the coaming in place (as much as you can) and carefully apply the CA glue. Put more of the coaming in place and apply more CA - kinda like you glue a little at a time as you go.
