RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   Powering a Hog Bipe (https://www.rcuniverse.com/forum/kit-building-121/3765528-powering-hog-bipe.html)
christoph 01-12-2006 12:47 PM
Powering a Hog Bipe
How do you think a Saito 82 will do in a Hog Pipe?
tashley 01-12-2006 12:59 PM
RE: Powering a Hog Bipe
I think it would be on the low end power wise if you intend on having lively performance but if you want something to cruise around on a nostalgic kind of day I think it will be fine.
RCKen 01-12-2006 01:49 PM
christoph,
I don't know, you may be a tad bit underpowered with that motor. I have an OS 91 4-stroke on mine and I feel that's a perfect match for the Hog Bipe. You might be happier with a Saito 100 if you want to stay with a Saito engines, if not get an OS 91. IMHO this plane was maid for the OS 91 4-stroke, or the other way around because they are a perfect match.
Ken
tashley 01-12-2006 02:10 PM
Ken's probably right but the Saito.82 is a stroooooong motor. I have one and it's one of my favs.
RCKen 01-12-2006 03:18 PM
I based my answer on the fact that they say the Saito 100 has the same power as the OS 91 FS.
Ken
WCB 01-12-2006 07:57 PM
"I based my answer on the fact that they say the Saito 100 has the same power as the OS 91 FS."
Ken
Oh come on now Ken ...who is "they"?......OS?:D
chrisfo 01-12-2006 10:21 PM
According to published specs, it looks like the saito is almost 5 ounces lighter and puts out 1.5 hp verses 1.6 hp with the os 91. Seems pretty close to me :eek:
Chris
FlyingPilgrim 01-12-2006 11:07 PM
.91 Saito or Os .91
chrisfo 01-13-2006 08:47 AM
91 os 82 saito
bhole74 01-13-2006 10:06 AM
ORIGINAL: RCKen
Ken
The Saito has more, I've had both, still have the Saito. More RPM with the same prop.
LMProd 01-25-2006 09:27 PM
I have a OS 70 on mine. It flys like a Bi Plane.
EscapeFlyer 01-25-2006 10:15 PM
Okay, all you 4cycle guys can rip on me all you want- I'm using my ST .90. I'm curious to see what she does or doesn't do!
All I've run on my airplanes are Saitos, YS, and Magnum 4 cycles. I want to experiment with the 2 strokers for awhile. If I truley am dissapointed I'll put my Saito 1.00 in her.
[email protected] 02-07-2006 06:03 PM
ilikebipes, if you insist on running a dirty old two stroke in this beautiful bipe, please run it inverted, and run an exhaust extension out the bottom, ala tiger moth. would be an interesting "bash" of the front end. mike
EscapeFlyer 02-07-2006 10:14 PM
Actually, it's a new "dirty old 2cycle" that I didn't have a home for. Apparently I let my Saito 1.00 sit too long without rubbing some elbow grease into it. The rear bearing rusted. It is currently a basket case untill I purchase a new bearing and gasket set.
Of course, I could use my YS 1.20....... Hmmmmm!
